Change modes with button
Hello,
How can I make a button change program mode while the loop is running?
I want to do an RGB led cube, I want to change modes directy in loop… Have I to check the button input after every action?
As example:
(example, in finished code, there will be a LOT of actions)
while (mode == 1) {
while (fadeValue < 255) {
fadeValue++;
analogWrite(ledPin, fadeValue);
delay(5);
if (digitalRead(buttonPin) = HIGH) {
mode++;
while (mode == 2) {
Is there a trick that I don´t have to check the input every action?
Yes.
Yes. Don’t use delay() (see the blink without delay example); use a state machine to keep track of what to do on this pass through loop() if the switch is not pressed.
Thank you :smiley:
while (mode = 1)
There's another trick to learn here too.
AWOL:
while (mode = 1)
while (mode == 1)
Notice the difference?
Grumpy_Mike:
while (mode == 1)
:grin: I just wanted to make a general overview, it shouldn´t be right down to the smallest detail :grin:
It's a nice thought, but the compiler disagrees.
Your redaction missed one (though in this case, the compile wouldn't)
You also missed the code tags.
