Change Padnote
Hallo
Can you help ,please.
I have Drum Kit Kit AI.
I want to cange Padnote
Basic setting is
unsigned char PadNote[6] = {60,61,62,63,64,65}; // MIDI notes from 0 to 127 (Mid C = 60)
I need for examle
unsigned char PadNote[6] = {49,50,61,63,64,65}; // MIDI notes from 0 to 127 (Mid C = 60)
But If I upload new code , nothing is change!!! Still is 60...65
If I change example
,,boolean VelocityFlag = true/false "
Velocity of pads is changed.
Thank you for you help
Mirek
Prague Cz
Can you post all the code?
Here is link .
http://www.spikenzielabs.com/SpikenzieLabs/Serial_MIDI_files/application.windows_2.zip
I uploaded the same code.
One more thing
It is recommended to choose Diecimila / AT mega168
but I must choose arduino dumilanove w/ ATmega 328 board than I can upload .
Here is link .
No, post your code - the actual code you're using.
Use code tags.
I tried post code but is too long/9000 / and I can't send tags
I sorry for trouble I am beginner.:wink:
Link with zip there is file for Arduino.
Thank for you interest.
Here is first 1/3
/ User settable variables
int PadCutOff[6] = {700,700,700,700,700,700};            // Minimum Analog value to cause a drum hit
int MaxPlayTime[6] = {90,90,90,90,90,90};                // Cycles before a 2nd hit is allowed
#define  midichannel	0;                               // MIDI channel from 0 to 15 (+1 in "real world")
boolean VelocityFlag  = false;                           // Velocity ON (true) or OFF (false)
// Number of Drum Pads used
#define NumPads 6                                        // Number of drum pads (and visual feedback leds) used (Up to 6)               <- NEW
// NOTE: Drum pads are numbered from left to right when facing the DKKAI's screw terminals.
// If you are using less than six pads, connected the pads starting from left to right.
// Added to increase the speed of the drum kit by not scanning drum pads that are not used.
// Default LED color values per color per drum pad
int R_pad[6] = {1023,1023,1023,1023,1023,1023,};         // Red color values (0 to 1023, where 0 is off and 1023 is full on)            <- NEW
int G_pad[6] = {0,0,0,0,0,0,};                           // Green
int B_pad[6] = {0,0,0,0,0,0,};                           // Blue
// Note: There are six values for each primary color. The values correspond to the drum pads, that is why there are six values.
//       All the values must be filled, ie inside the {} brackets you must have six values.
//       Make secondary colors by mixed two or more other colors.
// Internal Use Variables and Constants
// For the ShiftBrite
#define clockpin 13                                      // CI
#define enablepin 10                                     // EI
#define latchpin 9                                       // LI
#define datapin 11                                       // DI
int LEDChannels[NumPads][3] = {0};
int SB_CommandMode;
int SB_RedCommand;
int SB_GreenCommand;
int SB_BlueCommand;
boolean activePad[6] = {0,0,0,0,0,0};                   // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0,0,0};                     // Counter since pad started to play
unsigned char status;
int pin = 0;
int hitavg = 0;
int val = 0;
int val2 = 0;
int *TempColorPtr;
int CurrentColor = 1;
int RPGpin =0 ;
int PlayModeLED = 7;                                    // DKKAI Roadie Led Pins
int NoteSelectLED = 8;
int AUXSelectLED = 2;
int PadSelectedLED = 3;
int ModeSelectBut = 6;                                  // DKKAI Roadie Button Pins
int UpBut = 5;
int DownBut = 4;
int SampTime = 100;
int mode = 1;
// Setup
#include <EEPROM.h>
  pinMode(ModeSelectBut, INPUT);                         // Set Button Pins to inputs
  pinMode(UpBut, INPUT);
  pinMode(DownBut, INPUT);
  pinMode(PlayModeLED, OUTPUT);                          // Set LED pins to outputs
  pinMode(NoteSelectLED, OUTPUT);
  pinMode(AUXSelectLED, OUTPUT);
  pinMode(PadSelectedLED, OUTPUT);
  digitalWrite(ModeSelectBut, HIGH);                     // Set internal pull-up to high on button pins
  digitalWrite(UpBut, HIGH);
  digitalWrite(DownBut, HIGH);
  digitalWrite(PlayModeLED, HIGH);                       // Default LED state
  digitalWrite(NoteSelectLED, LOW);
  digitalWrite(AUXSelectLED, LOW);
  digitalWrite(PadSelectedLED, LOW);
  delay(250);
  Serial.begin(57600);                                  // connect the serial port Use 31250 for MIDI [default serial DKK 57600]
  val = EEPROM.read(7);                                 // Position 7 in EEPROM used to see if it has Note data
  if(val != 78)                                         // (if it is not "78" then we never filled EEPROM, do it now.)
    FILLEEPROM();
  } else
    GETNOTESFROMEEPROM();
  pinMode(datapin, OUTPUT);                             // Pin Set-up for Macetech ShiftBrites
  pinMode(latchpin, OUTPUT);
  pinMode(enablepin, OUTPUT);
  pinMode(clockpin, OUTPUT);
  SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR1)|(0<<SPR0);
  digitalWrite(latchpin, LOW);
  digitalWrite(enablepin, LOW);
  docolor(0,0,0, 1000);
2/3
// Main Program
  switch (mode)
  case 1:                                                         // Normal Drum Playing
    for(int pin=0; pin < NumPads; pin++)
      hitavg = analogRead(pin);                              // read the input pin
        if((hitavg > PadCutOff[pin]))
        if((activePad[pin] == false))
          if(VelocityFlag == true)
            //          hitavg = 127 / ((1023 - PadCutOff[pin]) / (hitavg - PadCutOff[pin]));    // With full range (Too sensitive ?)
            hitavg = (hitavg / 8) -1 ;                                                 // Upper range
            hitavg = 127;
          MIDI_TX(144,PadNote[pin],hitavg);
          VisualFeedBack(R_pad[pin],G_pad[pin],B_pad[pin], pin);
          PinPlayTime[pin] = 0;
          activePad[pin] = true;
          PinPlayTime[pin] = PinPlayTime[pin] + 1;
      else if((activePad[pin] == true))
        if(PinPlayTime[pin] > MaxPlayTime[pin])
          activePad[pin] = false;
          MIDI_TX(128,PadNote[pin],127);
          VisualFeedBack(0,0,0, pin);
    val = digitalRead(ModeSelectBut);
    if(val == 0)
      mode = 2;
      digitalWrite(NoteSelectLED, HIGH);
      digitalWrite(PlayModeLED, LOW);
      do
      while(val == 0);
      delay(100);
  case 2:                                                 // Re programming NOTEs Mode (wait for a Pad to be selected)
    val = val;
        mode = 3;
        RPGpin = pin;
        digitalWrite(PadSelectedLED, HIGH);
      if(val == 0)
        mode = 4;
        digitalWrite(AUXSelectLED, HIGH);
        do
        while(val == 0);
        delay(100);
  case 3:                                                         // Re programming NOTEs Mode
    val = digitalRead(UpBut);
    if(val == 0)
      PadNote[RPGpin] = PadNote[RPGpin]+1;
      if(PadNote[RPGpin] > 127)
        PadNote[RPGpin] = 127;
      MIDI_TX(144,PadNote[RPGpin],127);
      delay(SampTime);
      MIDI_TX(128,PadNote[RPGpin],0);
      do
      while(val == 0);
      delay(100);
    val = digitalRead(DownBut);
    if(val == 0)
      PadNote[RPGpin] = PadNote[RPGpin]-1;
      if(PadNote[RPGpin] < 1)
        PadNote[RPGpin] = 1;
      delay(SampTime);
      do
      while(val == 0);
      delay(100);
    hitavg = analogRead(RPGpin);                                        // read the input pin
    if((hitavg > PadCutOff[RPGpin]))
      delay(SampTime);
    val = digitalRead(ModeSelectBut);                                   // Exit to normal play
    if(val == 0)
      mode = 1;
      FILLEEPROM();
      do
      while(val == 0);
      delay(100);
  case 4:                                                 // Re programming AUX Mode (wait for a Pad to be selected)
    val = val;
        mode = 5;
        RPGpin = pin;
        TempColorPtr = &R_pad[RPGpin];
        VisualFeedBack(1023,0,0, RPGpin);
        VisualFeedBack(R_pad[RPGpin],G_pad[RPGpin],B_pad[RPGpin], RPGpin);
      if(val == 0)
        mode = 1;
        do
        while(val == 0);
        delay(100);
  case 5:                                                 // Re programming AUX Mode
    val2 = digitalRead(DownBut);
    if(val == 0 && val2 != 0)
      *TempColorPtr = *TempColorPtr +100;
      if(*TempColorPtr>1023)
        *TempColorPtr = 1023;
    if(val2 == 0 && val != 0)
      *TempColorPtr = *TempColorPtr -100;
      if(*TempColorPtr<0)
        *TempColorPtr = 0;
    if(val2 == 0 && val == 0)
      CurrentColor = CurrentColor +1;
      if(CurrentColor > 3)
        CurrentColor =1;
      switch (CurrentColor)
      case 1:
        VisualFeedBack(0,0,0, RPGpin);
        delay(250);
      case 2:
        delay(250);
        TempColorPtr = &G_pad[RPGpin];
        VisualFeedBack(0,1023,0, RPGpin);
      case 3:
        delay(250);
        TempColorPtr = &B_pad[RPGpin];
        VisualFeedBack(0,0,1023, RPGpin);
    if(val == 0)
      mode = 1;
      do
      while(val == 0);
      delay(100);
    delay(250);
3/3
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY)
  status = MESSAGE + midichannel;
  Serial.write(status);
  Serial.write(PITCH);
  Serial.write(VELOCITY);
// Read MIDI notes for drum pads from EEPROM
void GETNOTESFROMEEPROM()
  int EEPadd;
  for(int EEPadd=0; EEPadd < 6; EEPadd++)
    PadNote[EEPadd] = EEPROM.read(EEPadd);
// Save changed (or first time run) MIDI notes to EEPROM
void FILLEEPROM()                                          // Normally only run once if EEPROM is clear
  int EEPadd;
    EEPROM.write(EEPadd, PadNote[EEPadd]);
  EEPROM.write(7, 78);                                      // 78 is just a number we selected to show EEPROM was writen
// Update LED colors
void SB_SendPacket() {
  if (SB_CommandMode == B01) {
    SB_RedCommand = 120;
    SB_GreenCommand = 100;
    SB_BlueCommand = 100;
  SPDR = SB_CommandMode << 6 | SB_BlueCommand>>4;
  while(!(SPSR & (1<<SPIF)));
  SPDR = SB_BlueCommand<<4 | SB_RedCommand>>6;
  SPDR = SB_RedCommand << 2 | SB_GreenCommand>>8;
  SPDR = SB_GreenCommand;
void WriteLEDArray() {
  SB_CommandMode = B00;                                             // Write to PWM control registers
  for (int h = 0;h<NumPads;h++) {
    SB_RedCommand = LEDChannels[h][0];
    SB_GreenCommand = LEDChannels[h][1];
    SB_BlueCommand = LEDChannels[h][2];
    //    SB_SendPacket();
  delayMicroseconds(15);
  digitalWrite(latchpin,HIGH);                                     // latch data into registers
  digitalWrite(latchpin,LOW);
  SB_CommandMode = B01;                                            // Write to current control registers
  for (int z = 0; z < NumPads; z++) SB_SendPacket();
void docolor(int x, int y, int z, int d)
  LEDChannels[0][0] = x;
  LEDChannels[0][1] = y;
  LEDChannels[0][2] = z;
  WriteLEDArray();
void VisualFeedBack(int x, int y, int z, int padcolor)
  LEDChannels[padcolor][0] = x;
  LEDChannels[padcolor][1] = y;
  LEDChannels[padcolor][2] = z;
  WriteLEDArray();
