Change pointer variable repeatedly
hey,
I used this function to save data to a SD Cards, which works fine:
void saveAccToSD(float data[], int size, int orient, int sensor)
  Serial.println("Saving startet..");
  const char * saveName;
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  if (orient == 1  && sensor == 1)
    saveName = "dataxone.txt";
  else if (orient == 1  && sensor == 2)
    saveName = "dataxtwo.txt";
  else if (orient == 2  && sensor == 1)
    saveName = "datayone.txt";
  else if (orient == 2  && sensor == 2)
    saveName = "dataytwo.txt";
  File dataFile = SD.open(saveName, FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile)
    for (int i = 0; i < size; i++) {
      dataFile.println(data[i]);
    dataFile.close();
  //if the file isn't open, pop up an error:
    Serial.println("error opening datalog.txt");
  Serial.println("Saving ended");
Function call:
const int size=1000;
float axOne[size];
    int orient = 1;
    int sensor = 1;
    saveAccToSD(axOne, size, orient, sensor);
Now I want to change the function in order to change the names of the files being stored.
I’m using a variable “int buffBatchCounter”, which counts up.
It should store the files as (with e.g. int buffBatchCounter = 3):
saveName = "dataxtwo3.txt"
Thanks!
