Change PWM frequency on ATTINY85 to 10-1000HZ
Hi, is there a way on the ATTINY85 to program set frequencies on the PWM pins using TIMER 0. I use a PWM frequency library for the Arduino Nano and works fine with that, but I don't think it's compatible with the ATTINY85 part, but not sure. I need to be able to program the PWM pin frequency on the ATTINY85 to sweep a range from 10-1000HZ, is this possible on this part?
Thanks, Rob
Yes. Take a look at this:
