we have a center pivot irrigation model and were trying to change moisture sensors in a circle by using the number of revolutions from a motor. We have 6 sensors in 3 different sections with two sensors in each section. Each sensor is controlling flashing LEDs and we need to switch between sensors/sections as it travels around the circle.
here is are code so far we. we need to get the sensors to switch and it will read that sensor based on the section that it is in.
int led1 = 2;
int led2 = 3;int val;
int motorpin = 9;
int encoderPinA = 6;
int encoderPinB = 7;
int encoderPos = 0;
int encoderPinALast = LOW;
int n = LOW;unsigned long led1timer = 0;
unsigned long led2timer = 0;
int led1State = LOW;
int led2State = LOW;int sensor1 = 0;
int sensor2 = 1;
int sensor3 = 2;
int sensor4 = 3;
int sensor5 = 4;
int sensor6 = 5;void setup(){
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);pinMode(motorpin, OUTPUT);
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
}void loop(){
int MC1 = analogRead(sensor1);
int MC2 = analogRead(sensor2);
int MC3 = analogRead(sensor3);
int MC4 = analogRead(sensor4);
int MC5 = analogRead(sensor5);
int MC6 = analogRead(sensor6);int delaytime1 = (50 + 950/700 * MC1);
int delaytime2 = (50 + 950/700 * MC2);
int delaytime3 = (50 + 950/700 * MC3);
int delaytime4 = (50 + 950/700 * MC4);
int delaytime5 = (50 + 950/700 * MC5);
int delaytime6 = (50 + 950/700 * MC6);analogWrite(motorpin, 100);
n = digitalRead(encoderPinA);
if((encoderPinALast == LOW) && (n == HIGH)){
if(digitalRead(encoderPinB) == LOW)
encoderPos--;
else{
encoderPos++;
Serial.println(encoderPos/180);}
encoderPinALast = n;if((encoderPos> 0) && (encoderPos< 25))
(analogRead(sensor1));
digitalWrite(led1, delaytime1);
(analogRead(sensor2));
digitalWrite(led2, delaytime2);
}if((encoderPos> 25) && (encoderPos< 50))
(analogRead(sensor3));
digitalWrite(led1, delaytime3);
(analogRead(sensor4));
digitalWrite(led2, delaytime4);
if ((encoderPos> 50) && (encoderPos <75))
(analogRead(sensor5));
digitalWrite(led1, delaytime5);
(analogRead(sensor6));
digitalWrite(led2, delaytime6);
}if ( (millis () - led1timer) >= delaytime1) {
if (led1State == LOW)
led1State = HIGH;
led1State = LOW;
digitalWrite (led1, led1State );
led1timer = millis ();
if ( (millis () - led2timer) >= delaytime2 ) {
if (led2State == LOW)
led2State = HIGH;
led2State = LOW;
digitalWrite (led2, led2State );
led2timer = millis () ;
if ( (millis () - led1timer) >= delaytime3) {
led1State = HIGH;
led1State = LOW;
if ( (millis () - led2timer) >= delaytime4 ) {
led2State = HIGH;
led2State = LOW;
// if ( (millis () - led1timer) >= delaytime5) {
// if (led1State == LOW)
// led1State = HIGH;
// else
// led1State = LOW;
// digitalWrite (led1, led1State );
// led1timer = millis ();
// if ( (millis () - led2timer) >= delaytime6 ) {
// if (led2State == LOW)
// led2State = HIGH;
// else
// led2State = LOW;
// digitalWrite (led2, led2State );
// led2timer = millis () ;
