Change Serial Port Communication to Rising Edge Triggered
Hi all,
I’m using serial port to output data in a buffer continuously as following.
It works well. But the data is triggered by falling edge.
Is it possible to change it to rising edge triggered type?
How can I modified my code?
Thanks.
uint8_t  g_Buffer1[] = {0xAA,0xBB,0xCC};
uint8_t count1 = 0;
  Serial.begin(9600); // initialize serial
  USART_MSPIM_Init(); // initialize MSPIM mode
  SPCR = (1 << SPE);  // enable SPI
  TIMSK0 = 0;         // disable timer0
    if ((UCSR0A & 32) != 0) {    // transmit when data register empty
        UDR0 = g_Buffer1[count1]; //transfer code
        count++;
void USART_MSPIM_Init()
  UBRR0H = 0;
  UBRR0L = 0;
  DDRD |= _BV (4);                                             // XCK as output enables master mode
  UCSR0C = (1 << UMSEL01) | (1 << UMSEL00) | (0 << UCPHA0) | (0 << UCPOL0); // Master SPI, mode 0
  UCSR0B = (1 << RXEN0) | (1 << TXEN0);                        // Enable receiver and transmitter
  UBRR0L = 7;                                                  // 1MHz XCK on pin 4
Try with UCSR0C = (1 << UMSEL01) | (1 << UMSEL00) | (0 << UCPHA0) | (1 << UCPOL0);
ard_newbie:
Yes, it worked, Thank you so much!
