Change SoftwareSerial-Pins on runtime?
Hi to all,
I got stuck with a rather rare problem, but nevertheless a headache for me.
With my Arduinos (UNO/MEGA) I use different GSM-Shields. These shields request also different SoftwarSerial-pins, e.g. one shield works via pins 2 and 3, the other via pins 7 and 8.
As I do not want to recompile the sketch each time I change a GSM-shield (can happen, if the active shield has a failure), I want to figure out, which pins are used for the active shield.
The attached example is used for a shield, which works perfectly with pins 2 and 3. So if I try to make it function with pins 7 and 8, it does not work (this I can see by the missing response to the "AT"-command) and then I want to switch the pins to pins 2 and 3 by assigning another SoftwareSerial- variable (here myserial2 shall be assigned instead of the default myserial.
But obviously this assignment does not work - I cannot modify the pins on runtime (the output of "YYY" is only to debug the entry into the "modification-part".
So my question: How can I change the SoftwareSerial-pins on runtime????
#include <SoftwareSerial.h>
  SoftwareSerial mySerial2(2,3);  //OK
  SoftwareSerial mySerial(7,8);   //NOK
  pinMode(9, OUTPUT);     // Simulation of "Power On" Button
  digitalWrite(9, HIGH);  // Simulation of "Power On" Button
  delay(3000);            // Simulation of "Power On" Button
  digitalWrite(9, LOW);   // Simulation of "Power On" Button
  delay(2000);            // Simulation of "Power On" Button
  Serial.println("Start Calling");
  mySerial.begin(9600);
  mySerial.println("AT"); //Send Request to GSM
  delay (1000);
  if (mySerial.available()<=0) // Did GSM answer?
    Serial.println("YYYYY");
    mySerial=mySerial2;        // No, modify Ports <==========
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
Have a nice day - and hopefully an idea...
piqueremy
There is nothing wrong with that second declaration, except the name. You do NOT have a mySerial connected to those pins. Why not use a name that makes sense, based on what IS connected to those pins?
That does not make sense. You could just use mySerial2.begin().
The return value from available() can NEVER be less than 0.
You could add a method to the SoftwareSerial class to allow changing pins.
Well,
thank you for your fast reply.
Just some comments:
  • as it's a sample sketch, I did not care about the naming.
  • As a long-term programmer (>40 yrs,starting with Assembler, then FORTRAN, BASIC,PASCAL,CHILL..) I got used to exclude the impossible as well.Even if mySerial.available() should not be <0, I got used (out of some bad experiences with long debugging sessions), to include the impossible as well. It does not hurt, except a compiler might think "Oh, what a stupid programmer....
  • If I use "mySerial2.begin()." I have to separate the following, rather large programm according to "mySerial" and "mySerial2". This would mean a rather big effort.
So I followed your last hint and added a method "Change_pins" to the SWS-Library and it works perfectly.
Maybe in an official version of the SoftwareSerial-library it can be implemented as well, even if this problem is a rather rare situation.
At the beginning my new method did not work, and after diving into the SoftwareSerial.cpp I found a method"end" - and this was the clue.
So I created another library "NewSoftwareSerial" (which contains the official "SoftwareSerial and my "Change_pins"-method) and included it into my sketch - and voila!
Thanks for your help and have a nice day:
Piqueremy
#include <NewSoftwareSerial.h>
//  NewSoftwareSerial mySerial(2,3);  //OK
  NewSoftwareSerial mySerial(7,8);   //NOK
  delay (1000);
      mySerial.end();
      mySerial.Change_pins(2,3);        // No, modify Ports <==========
  delay (1000);
      delay(1000);            // Simulation of "Power On" Button
  delay (1000);
    mySerial.end();
    mySerial.Change_pins(7,8);        // No, modify Ports <==========
NewSoftwareSerial.h (4.01 KB)
NewSoftwareSerial.cpp (13.4 KB)
keywords.txt (680 Bytes)
