Change SSID of ESP32 as AP
When applying the standard example of OTA updates of an ESP32 with a web server using the Arduino IDE ("OTAWebUpdater"), it does not seem possible to change the value of the AP SSID after the script is uploaded for the first time. This issue has appeared multiple times, e.g. https://forum.arduino.cc/t/esp32-ssid-will-not-change/602849, but was not answered satisfactorily.
The solution is simple if hard to find when you lack full understanding of the upload process: in the tools menu of the Arduino IDE enable the option "Erase All Flash Before Sketch Upload".
#include <WiFi.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <Update.h>
#include <Ticker.h>
#include "html.h"
#define SSID_FORMAT "ESP32-%06lX"  // 12 chars total
//#define PASSWORD "test123456"    // generate if remarked
// Set the username and password for firmware upload
const char *authUser = "........";
const char *authPass = "........";
WebServer server(80);
Ticker tkSecond;
uint8_t otaDone = 0;
const char *csrfHeaders[2] = {"Origin", "Host"};
static bool authenticated = false;
const char *alphanum = "0123456789!@#$%^&*abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ";
String generatePass(uint8_t str_len) {
  String buff;
  for (int i = 0; i < str_len; i++) {
    buff += alphanum[random(strlen(alphanum) - 1)];
  return buff;
void apMode() {
  char ssid[13];
  char passwd[11];
  long unsigned int espmac = ESP.getEfuseMac() >> 24;
  snprintf(ssid, 13, SSID_FORMAT, espmac);
#ifdef PASSWORD
  snprintf(passwd, 11, PASSWORD);
#else
  snprintf(passwd, 11, generatePass(10).c_str());
#endif
  WiFi.mode(WIFI_AP);
  WiFi.softAP(ssid, passwd);  // Set up the SoftAP
  MDNS.begin("esp32");
  Serial.printf("AP: %s, PASS: %s\n", ssid, passwd);
void handleUpdateEnd() {
  if (!authenticated) {
    return server.requestAuthentication();
  server.sendHeader("Connection", "close");
  if (Update.hasError()) {
    server.send(502, "text/plain", Update.errorString());
    server.sendHeader("Refresh", "10");
    server.sendHeader("Location", "/");
    server.send(307);
    ESP.restart();
void handleUpdate() {
  size_t fsize = UPDATE_SIZE_UNKNOWN;
  if (server.hasArg("size")) {
    fsize = server.arg("size").toInt();
  HTTPUpload &upload = server.upload();
  if (upload.status == UPLOAD_FILE_START) {
    authenticated = server.authenticate(authUser, authPass);
      Serial.println("Authentication fail!");
      otaDone = 0;
      return;
    String origin = server.header(String(csrfHeaders[0]));
    String host = server.header(String(csrfHeaders[1]));
    String expectedOrigin = String("http://") + host;
    if (origin != expectedOrigin) {
      Serial.printf("Wrong origin received! Expected: %s, Received: %s\n", expectedOrigin.c_str(), origin.c_str());
      otaDone = 0;
      return;
    Serial.printf("Receiving Update: %s, Size: %d\n", upload.filename.c_str(), fsize);
    if (!Update.begin(fsize)) {
      otaDone = 0;
      Update.printError(Serial);
  } else if (authenticated && upload.status == UPLOAD_FILE_WRITE) {
    if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
      otaDone = 100 * Update.progress() / Update.size();
  } else if (authenticated && upload.status == UPLOAD_FILE_END) {
    if (Update.end(true)) {
      Serial.printf("Update Success: %u bytes\nRebooting...\n", upload.totalSize);
      Serial.printf("%s\n", Update.errorString());
      otaDone = 0;
void webServerInit() {
  server.collectHeaders(csrfHeaders, 2);
  server.on(
    "/update", HTTP_POST,
      handleUpdateEnd();
      handleUpdate();
  server.on("/favicon.ico", HTTP_GET, []() {
    server.sendHeader("Content-Encoding", "gzip");
    server.send_P(200, "image/x-icon", favicon_ico_gz, favicon_ico_gz_len);
  server.onNotFound([]() {
    if (!server.authenticate(authUser, authPass)) {
    server.send(200, "text/html", indexHtml);
  server.begin();
  Serial.printf("Web Server ready at http://esp32.local or http://%s\n", WiFi.softAPIP().toString().c_str());
void everySecond() {
  if (otaDone > 1) {
    Serial.printf("ota: %d%%\n", otaDone);
  apMode();
  webServerInit();
  tkSecond.attach(1, everySecond);
  delay(150);
  server.handleClient();
The answer is already in the question. This topic is meant as a service to the readers of the forum, so frequent contributors, please be not annoyed that this question deviates from the standard format that you insist that questioners use.
