Change State
Hi Guys,
Could someone help me please with the following code, the code is supposed to move a motor forward then backward after it detects the change state of a microswitch, it does this as expected but it keeps on repeating while the switch is closed, I only want it to cycle once after the change state and then wait for it to go from low to high again before another cycle?
#include <AFMotor.h>
const int stopLightPin = 2; // input from “STOP LIGHT” output
const int startPin = 9; // output via relay to start cycle
const int homePin = 11; // microswitch for home position
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int markState = 0; // variable for reading the pushbutton status
AF_Stepper motor(200, 2);
// initialize the LED pin as an output:
pinMode(startPin, OUTPUT);
pinMode(stopLightPin, INPUT); //Maybe change this to pulldown if erratic
pinMode(homePin, INPUT_PULLUP);
// read the state of the pushbutton value
buttonState = digitalRead(stopLightPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState != lastButtonState) {
if (buttonState == HIGH) {
buttonPushCounter++;
motor.setSpeed(100);
motor.step(2450, BACKWARD, DOUBLE); // DOUBLE or INTERLEAVE or MICROSTEP!
delay(100);
motor.step(2450, FORWARD, DOUBLE);
// in other words do nothing
//digitalWrite(startPin, LOW);
delay(100);
regards
Andrew
You aren’t setting lastButtonState after you read the new value.
I find it more sensible to save the previous button state just before reading it again.
  lastButtonState = buttonState;
That way the two actions are close together in the code and make more sense to me when I read the code again.
I usually put that first thing after "if (buttonState != lastButtonState) {" because at that point you no longer need the old value and if the comparison is false (they are equal) there is no need to change lastButtonState.
Thanks guys, all working now thanks to you.
Andrew
