I'm wondering is it possible to change the chronodot's address to different pins on the arduino board and have the co2 sensor(k30 co2 meter) on the i2c pins for mega 2560? or vice versa
This is my current code ---and I was using the UART PINS but I had an accident and I can no longer use the TX pin.
#include "SoftwareSerial.h"
#include "SD.h"
#include "Wire.h"
SoftwareSerial K_30_Serial(12,13); //Sets up a virtual serial port
//Using pin 13 for Rx and pin 12 for Tx
byte readCO2[]={0xFE, 0X44, 0X00, 0X08, 0X02, 0X9F, 0X25}; //Command packet to read Co2 (see app note)
byte response[]={0,0,0,0,0,0,0}; //create an array to store the response
//multiplier for value. default is 1. set to 3 for K-30 3% and 10 for K-33 ICB
int valMultiplier = 10;
int pin =8;
unsigned long duration;
unsigned long starttime;
unsigned long sampletime_ms=3000;//sampe 30s ;
unsigned long lowpulseoccupancy=0;
float ratio=0;
float concentration=0;
int temperatureCommand=3;
int humidityCommand=5;
int clockPin=2;
int dataPin=3;
int val;
int ack;
float temperature;
float humidity;
const int chipSelect=53;
float refresh_rate=0.0;
long Num=1;
K_30_Serial.begin(9600);
Wire.begin();
Serial.print("Initializing SD card...");
Wire.beginTransmission(0x68); // address DS3231
Wire.write(0x0E); // select register
Wire.write(0b00011100); // w
pinMode(53, OUTPUT);
pinMode(28,INPUT);
starttime = millis();//get the current time;
pinMode (22,INPUT);
pinMode (23,INPUT);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Serial.println("card initialized.");
File commandFile= SD.open("COMMANDS.txt");
if (commandFile)
Serial.println("Reading Command File");
float decade=pow(10,(commandFile.available()-1));
while
(commandFile.available())
float temp= (commandFile.read()-'0');
refresh_rate= temp* decade + refresh_rate;
decade=decade/10;
Serial.print("Refresh Rate=");
Serial.print(refresh_rate);
Serial.println("ms");
commandFile.close();
Serial.println("Could not readd command File");
return;
File logFile=SD.open("LOG25.csv",FILE_WRITE);
if (logFile)
logFile.println(",,,,");
String header= "Num,Temperature,Humidity,CO2,Dust concentration,time";
logFile.println(header);
logFile.close();
Serial.println(header);
Serial.println ("Couldn't Open log file");
{sendRequest(readCO2);
unsigned long valCO2 = getValue(response);
Serial.print("Co2 ppm = ");
Serial.println(valCO2);
delay(refresh_rate);
duration = pulseIn(pin, LOW);
lowpulseoccupancy = lowpulseoccupancy+duration;
if ((millis()-starttime) > sampletime_ms)//if the sampel time == 30s
ratio = lowpulseoccupancy/(sampletime_ms*10.0); // Integer percentage 0=>100
concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve
Serial.print(lowpulseoccupancy);
Serial.print(",");
Serial.print(ratio);
Serial.print(",");
Serial.println(concentration);
lowpulseoccupancy = 0;
delay (refresh_rate);
sendCommandSHT(temperatureCommand, dataPin, clockPin);
waitForResultSHT(dataPin);
val = getData16SHT(dataPin, clockPin);
skipCrcSHT(dataPin, clockPin);
temperature = (float)val * 0.01 - 40;
temperature = (float)temperature;
sendCommandSHT(humidityCommand, dataPin, clockPin);
humidity = -4.0 + 0.0405 * val + -0.0000028 * val * val;
Serial.print(temperature*100);
Serial.println(humidity*100);
// send request to receive data starting at register 0
Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
Wire.write((byte)0); // start at register 0
Wire.endTransmission();
Wire.requestFrom(0x68, 3); // request three bytes (seconds, minutes, hours)
while(Wire.available())
int seconds = Wire.read(); // get seconds
int minutes = Wire.read(); // get minutes
int hours = Wire.read(); // get hours
seconds = (((seconds & 0b11110000)>>4)*10 + (seconds & 0b00001111)); // convert BCD to decimal
minutes = (((minutes & 0b11110000)>>4)*10 + (minutes & 0b00001111)); // convert BCD to decimal
hours = (((hours & 0b00100000)>>5)*20 + ((hours & 0b00010000)>>4)*10 + (hours & 0b00001111)); // convert BCD to decimal (assume 24 hour mode)
Serial.print(hours); Serial.print(":"); Serial.print(minutes); Serial.print(":"); Serial.println(seconds);
delay (1000);
String dataString= String(Num)+","+String(temperature)+","+String(humidity)+","+String(valCO2)+","+String(concentration)+","+String (hours)+":"+String(minutes)+":"+String (seconds);
File logFile= SD.open("LOG25.csv",FILE_WRITE);
if (logFile)
logFile.println(dataString);
logFile.close();
Serial.println(dataString);
Serial.println("couldn't open log File");
Num++;
void sendRequest(byte packet[])
while(!K_30_Serial.available()) //keep sending request until we start to get a response
K_30_Serial.write(readCO2,7);
delay(50);
int timeout=0; //set a timeoute counter
while(K_30_Serial.available()< 7) //Wait to get a 7 byte response
timeout++;
if(timeout>10) //if it takes to long there was probably an error
while(K_30_Serial.available()) //flush whatever we have
K_30_Serial.read();
break; //exit and try again
delay(50);
for (int i=0; i <7; i++)
response[i]=K_30_Serial.read();
unsigned long getValue(byte packet[])
int high = packet[3]; //high byte for value is 4th byte in packet in the packet
int low = packet[4]; //low byte for value is 5th byte in the packet
unsigned long val = high*256 + low; //Combine high byte and low byte with this formula to get value
return val* valMultiplier;
int shiftIn(int dataPin, int clockPin, int numBits) {
int ret = 0;
for (int i=0; i<numBits; ++i) {
digitalWrite(clockPin, HIGH);
//delay(10); not needed :)
ret = ret*2 + digitalRead(dataPin);
digitalWrite(clockPin, LOW);
return(ret);
// send a command to the SHTx sensor
void sendCommandSHT(int command, int dataPin, int clockPin) {
int ack;
// transmission start
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(dataPin, HIGH);
digitalWrite(dataPin, LOW);
// shift out the command (the 3 MSB are address and must be 000, the last 5 bits are the command)
shiftOut(dataPin, clockPin, MSBFIRST, command);
// verify we get the right ACK
pinMode(dataPin, INPUT);
ack = digitalRead(dataPin);
if (ack != LOW)
Serial.println("ACK error 0");
if (ack != HIGH)
Serial.println("ACK error 1");
// wait for the SHTx answer
void waitForResultSHT(int dataPin) {
int ack;
for(int i=0; i<100; ++i) {
delay(10);
if (ack == LOW)
if (ack == HIGH)
Serial.println("ACK error 2");
// get data from the SHTx sensor
int getData16SHT(int dataPin, int clockPin) {
int val;
// get the MSB (most significant bits)
val = shiftIn(dataPin, clockPin,8);
val *= 256; // this is equivalent to val << 8;
// send the required ACK
// get the LSB (less significant bits)
val |= shiftIn(dataPin, clockPin,8);
return val;
// skip CRC data from the SHTx sensor
void skipCrcSHT(int dataPin, int clockPin){
