change timestep for pwm
I currently have a PWM signal with 50% duty cycle, but how would I do to get a PWM signal that is 200 timesteps as high and 55 timesteps as low? Not sure how to do the actual coding part for setting the timesteps.
What code did you use to get the 50% duty cycle PWM?
Steve
slipstick:
Steve
In my setup i simply use analogWrite(PIN,127), since my resolution is 255(100%)
So don't you think that analogWrite(PIN,200) will be all you need?
Steve
