Hi I'm really new to arduino. I've worked with some microcontrollers before but not alot. I've also got some skills in C++ but they are really rusty.
My question is, I'm trying to use an impulse button for my Arduino Nano to change part in my code, but I can't get it to work. Probably my bad though.
I've got 6 LEDs connected individually to seperate pins on the arduino. The code for the patterns of the LEDs are working but i want to press the button and move on to the next type of pattern. I'll post my code here aswell in the hope that someone know how I can make it work!
I know that the button works in itself. Tested with an multimeter and have tested just turning one LED on and off.
(P.S. it's for an ugly christmas sweater)
//test button for arduino to change code-blocks.
int led = 3; // the PWM pin the LED is attached to
int led2 = 5;
int led3 = 6;
int led4 = 9;
int led5 = 10;
int led6 = 11;
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
pinMode(2, INPUT); //Push Button
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
int buttonState = digitalRead(2); //Read and store state of push Button
int buttonNumber = 0;
if (buttonState = LOW){
buttonNumber = buttonNumber + 1;
if (buttonNumber == 0){
// set the brightness of pin 9:
analogWrite(led, brightness);
analogWrite(led2, brightness);
analogWrite(led3, brightness);
analogWrite(led4, brightness);
analogWrite(led5, brightness);
analogWrite(led6, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255) {
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
else if (buttonNumber == 1){
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(100);
{digitalWrite(led2, HIGH);
delay(100);
digitalWrite(led2, LOW);
delay(100);}
{digitalWrite(led3, HIGH);
delay(100);
digitalWrite(led3, LOW);
delay(100);}
{digitalWrite(led4, HIGH);
delay(100);
digitalWrite(led4, LOW);
delay(100);}
{digitalWrite(led5, HIGH);
delay(100);
digitalWrite(led5, LOW);
delay(100);}
{digitalWrite(led6, HIGH);
delay(100);
digitalWrite(led6, LOW);
delay(100);}
else if (buttonNumber == 2){
// doubles skipping
else if (buttonNumber = 3){
buttonNumber = 0;
