Change variables in a function with parameters?
hi all,
I have a lot of button that need checking and do a Keyboard.write();
I want do write a function or a for-loop to do this for all the buttons.
my idea was:
CheckSwitch( 7, “state7”, “lastState7”, 65);
void CheckSwitch (int pin, String state, String lastState, int key)
state = digitalRead(pin);
if (state != lastState)
if (state == LOW)
Keyboard.write(key);
delay(50);
lastState = state;
it copiles, but give no output.
is it even possible to change variables inside a function like this?
could you recommend another way to do this?
Thank You :slight_smile:
Have you checked the return type of digitialRead? it's HIGH or LOW and these are constants, check this link
It makes no sense to try to store the value read from a pin in a String. It makes no sense to try to compare that String to LOW.
