Changeable Voice password
Hi all, could anyone help me on this? I'm now wanted to add a command called "enter" so that when this command was called, it only ask for password enter by user, otherwise it cannot performed anything.
The problem is that when I have speak the command "enter", it ask for enter password, but the password I speak doesnt run in the function. Below is my code.
#include "VoiceRecognitionV4.h" //VOICE using serial port library
VR myVR1(&Serial1);
VR myVR2(&Serial3);
uint8_t buf[32];
int led = 13;
int i=0;
const byte PasswordLength = 2;
const byte PasswordDigits[PasswordLength] = {1, 2};
byte EnteredDigits[PasswordLength];
byte EnteredDigitsIndex = 0;
byte newcode1[PasswordLength];
uint8_t VR1RecordEnables[7] =
  0, // Zero
  1, // One
  2, // Two
  3, // Three
  4, // Four
  5, // Five
  6, // Six
uint8_t VR2RecordEnables[5] =
  7, // Seven
  8, // Eight
  9, // Nine
  10, //changepassword
  11, //enter
  delay(200);
  Serial.println("Elechouse Voice Recognition V3 Module\r\nMulti Commands sample");
  /** initialize */
  Serial1.begin(9600);
  Serial3.begin(9600);
  pinMode(13, OUTPUT);
  digitalWrite(led, LOW); // Turn LED off
  if (myVR1.clear() == 0)
    Serial.println("Recognizer 1 cleared.");
    Serial.println("Not find VoiceRecognitionModule 1.");
    Serial.println("Please check connection and restart Arduino.");
    while (1);
  if (myVR2.clear() == 0)
    Serial.println("Recognizer 2 cleared.");
    Serial.println("Not find VoiceRecognitionModule 2.");
    while (1);
  if (myVR1.load(VR1RecordEnables, 7) >= 0)
    Serial.println(F("VR1 loaded."));
  if (myVR2.load(VR2RecordEnables, 5) >= 0)
    Serial.println(F("VR2 loaded."));
  int ret;
       ret = myVR1.recognize(buf, 50);
       if (ret > 0)
        if(buf[1] == 11)
            // voice recognized
           EnterDigit(buf[2]);
       ret = myVR2.recognize(buf, 50);
       if (ret > 0)
        if(buf[1] == 11) //enter command
          Serial.println("Enter password: ");
          EnterDigit(buf[1]);
void EnterDigit(byte digit)
   Serial.print("Entered digit: ");
   Serial.println(digit);
   EnteredDigits[EnteredDigitsIndex++] = digit;
      if (EnteredDigitsIndex >= PasswordLength)
       Serial.println("Entry complete.");
       for (int i = 0; i < PasswordLength; i++)
          if (PasswordDigits[i] != EnteredDigits[i])
           // Password mismatch
           Serial.println("password incorrect");
           EnteredDigitsIndex = 0;  // Start over
           return;
       // Success!
       Serial.println("password correct");
       digitalWrite(led,HIGH);
        return;
void GetNewCode1(byte digit)
  i=0;
  Serial.println("Enter a new code: ");
  delay(2000);
  while(buf[1] != 11)
    if(buf[1] != 11)
      newcode1[i] = EnteredDigits[i];
      i++;
Not good to put 11 in your list of entered digits. You are also ignoring the digits 7, 8, and 9.
How do you want the sketch to work?
Only the 11 command which is "Enter" was triggered, then it proceed to display enter password. After that user only can speak the password.
This is something I want. Because later on I have to set two condition.
1st condition: "Enter" command to let user proceed to enter the password which is predefined.
2nd condition: "changepassword" command to let user proceed to change the password which is predefined at the beginnning.
Thanks.
Any suggestion. How I going to define so that I wont confuse any digit from 0 to 9
I would do it something like this:
#include "VoiceRecognitionV4.h" //VOICE using HardwareSerial
// Requires Arduino MEGA 2560
VR VR1(&Serial1);
VR VR2(&Serial3);
const byte MaxPasscodeLength = 16;
char PasscodeDigits[MaxPasscodeLength] = "12";
char EnteredDigits[MaxPasscodeLength];
char NewPasscode1[MaxPasscodeLength];
char NewPasscode2[MaxPasscodeLength];
const int CHANGE_PASSWORD_COMMAND = 10;
const int ENTER_COMMAND = 11;
const int CLEAR_COMMAND = 12;
  0, // Zero
  1, // One
  2, // Two
  3, // Three
  4, // Four
  5, // Five
  6, // Six
uint8_t VR2RecordEnables[6] =
  7, // Seven
  8, // Eight
  9, // Nine
  10, // Changepassword
  11, // Enter
  12, // Clear
enum States {EnteringPasscode, Unlocked, EnteringNew1, EnteringNew2} State = EnteringPasscode;
  delay(200);
  /** initialize */
  Serial1.begin(9600);  // Arduino MEGA 2560 required
  Serial3.begin(9600);  // Arduino MEGA 2560 required
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  Serial.println("Locked. Say password digits followed by 'Enter' for access.");
  if (VR1.clear() == 0)
    Serial.println("VR1 cleared.");
    Serial.println("VR1 not found!");
    while (1);
  if (VR2.clear() == 0)
    Serial.println("VR2 cleared.");
    Serial.println("VR2 not found!");
    while (1);
  if (VR1.load(VR1RecordEnables, 7) >= 0)
    Serial.println("VR1 load failed!");
    while (1);
  if (VR2.load(VR2RecordEnables, 6) >= 0)
    Serial.println("VR2 load failed!");
    while (1);
  int input;
  do
    input = GetInput();
  while (input < 0);
  switch (State)
    case EnteringPasscode:
      if (input < 10 && EnteredDigitsIndex < MaxPasscodeLength - 1)
        EnteredDigits[EnteredDigitsIndex++] = input + '0';  // Convert to character
        EnteredDigits[EnteredDigitsIndex] = '\0'; // Null terminator
      if (input == CHANGE_PASSWORD_COMMAND)
        Serial.println("Can't change password while locked.");
        // Start Over
        EnteredDigits[0] = '\0';
      if (input == ENTER_COMMAND)
        // Does it match?
        if (strcmp(EnteredDigits, PasscodeDigits) == 0)
          // Yes.  Unlock.
          digitalWrite(LED_BUILTIN, HIGH);
          Serial.println("Unlocked. Say 'clear' to lock.");
          State = Unlocked;
          // Not a match
          Serial.println("Wrong password.  Try again.");
          // Start Over
      if (input == CLEAR_COMMAND)
        Serial.println("Input cleared. Say password digits followed by 'Enter' for access.");
        // Start Over
    case Unlocked:
        Serial.println("Say digits for new password followed by 'Enter'.");
        // Start Over
        NewPasscode1[0] = '\0';
        State = EnteringNew1;
      else if (input == CLEAR_COMMAND)
        Serial.println("Locking.  Say password digits followed by 'Enter' for access.");
        // Start Over
        Serial.println("Invalid input while unlocked.  Say 'Clear' to lock.");
    case EnteringNew1:
        NewPasscode2[EnteredDigitsIndex++] = input + '0';  // Convert to character
        NewPasscode2[EnteredDigitsIndex] = '\0'; // Null terminator
        if (EnteredDigitsIndex == 0)
          // EMPTY PASSWORD
          Serial.println("New password cannot be empty.  Say digits for new password followed by 'Enter'.");
          Serial.println("Repeat the new password followed by 'Enter'.");
          NewPasscode2[0] = '\0';
          State = EnteringNew2;
        Serial.println("Input cleared. Say digits for new password followed by 'Enter'.");
        Serial.println("Or say'Changepassword' to cancel change.");
        // Start Over
        Serial.println("Password change canceled.");
        State = Unlocked;
    case EnteringNew2:
        NewPasscode1[EnteredDigitsIndex++] = input + '0';  // Convert to character
        NewPasscode1[EnteredDigitsIndex] = '\0'; // Null terminator
        if (strcmp(NewPasscode1, NewPasscode2) == 0)
          Serial.println("New password set.  Say 'Clear' to lock.");
          strcpy(PasscodeDigits, NewPasscode1);  // Replace previous password
          Serial.println("Repeat did not match. Password change canceled. Say 'Clear' to lock.");
        State = Unlocked;
        Serial.println("Input cleared. Repeat digits for new password followed by 'Enter'.");
        // Start Over
        State = Unlocked;
int GetInput()
  uint8_t buf[32];
  int ret;
  // Check for input from VR1
  ret = VR1.recognize(buf, 50);
  if (ret > 0)
    return buf[2];
  // No input from VR1.  Check for input from VR2
  ret = VR2.recognize(buf, 50);
  if (ret > 0)
    return buf[2];
  return -1; // No input this time
Alright. I will take a look on it. Thanks very much.
