Changed PC's, now can't get IDE to connect with arduino
Recently changed PC's from an old Windows Vista to a new Windows 10 box. Reloaded the Arduino IDE but I can't seem to connect to my boards now. I've tried two different Uno clones which I believe to be good as well as a Nano cone, brand new out of the package with the same results. Also tried two different cables, so I don't think that's the problem.
Here is the error message:
Arduino: 1.6.13 (Windows 10), Board: "Arduino Nano, ATmega328"
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30,720 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes. avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x06 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x06 Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
In the Tools menu, all the boards show up as connecting to COM1.
When I try the "get board info" tool, it responds "Native serial port, can't obtain info."
When I look at the control panel under "Connected Devices" it says "USB 2.0-Serial Driver is unavailable."
It appears that my PC (or maybe it's just the IDE) is not recognizing my arduinos.
I'd appreciate any guidance anyone can give me.
Clones ?
Maybe try the CH340 drivers that are NOT included with the IDE
Ballscrewbob: Thanks! I think that fixed it!
