Changing 1 & 0 to On and Off
Hi All,
Can someone please explain to me how to change 1 & 0 to On and Off.
What im doing is digitally reading an input and then using a Sim900A module to sms the status to me.
but whats happening now is im recieving the following:
Input 1 is: 0
or
Input 1 is: 1
but what i Want is:
Input 1 is: Off
or
Input 1 is: On
Here is a Sample of my code.
#include <SoftwareSerial.h>
SoftwareSerial Sim900A(9, 10);
int input1 = 11;
int status1 = 0;
String msg;
 pinMode(input1, INPUT_PULLUP);
 Sim900A.begin(9600);
 Sim900A.println("AT+CMGDA=\"");
 Sim900A.println("DEL ALL\"");
 Sim900A.println("AT+CMGF=1");
 status1 = digitalRead(input1);
 Sim900A.available()>0;
 Sim900A.println("AT+CNMI=2,2,0,0,0");
 msg = Sim900A.readString();
 if (status1 == LOW)
 Sim900A.println("AT+CMGS=\"+27xxxxxxxxx\"\r"); //xxxxxxxxx is my cell number
 Sim900A.println(String("Input 1 Is: ") + String(status1));
 Sim900A.println((char)26);
 delay(100);
 Sim900A.println("DEL ALL\",0 ");
Please someone help!!!
  Sim900A.print("Input 1 Is: ");
  if (status1 == 1) {
    Sim900A.println("On");
  else {
    Sim900A.println("Off");
Or more concise but less beginner friendly by using the ternary operator:
  Sim900A.println(status1 == 1 ? "On" : "Off");
Put the words you want to print in an array of chars and use the value returned to display the text using the value as the array index.
char * names[] = {"off", "on"};
  Serial.println(names[0]);
  Serial.println(names[1]);
Note the use of C strings rather than Strings
Thank You so much!!
This one works perfectly!
There is only one question that i have, and that is only to understand what i have written:
This part means:
[code]
that if status1 is equals to 1 then its on. of it equals to 0 then its off.
if i write it like this:
[code]
  Sim900A.println(status1 == 0 ? "On" : "Off");
[code]
then it means that 0 = to on and 1 = to off??
thanks again!
SlevenCalevra:
This part means:
Yes, that's what it will print. It's functionally the exact same code as this:
pert:
if (status1 == 1) {
else {
Only written in a different way, that takes less typing but is also harder to read.
SlevenCalevra:
Give it a try.
