Good day,
Following code is a part of the project which i trimmed so as to post on the forum and focus on the issue.
The code works such the there are two text files on the sd card.
One named set.txt which values 0016, 0004 which is converted to 16 (column) and 4 9row) respectively for 2 dimension array named sequence[row][col];
Second file contains led blink pattern in decimal format
eg:
240,15,28,192,174,186,0,0,170,238,56,145,
255,255,227,70,207,6,151,13,130,174,3,124,
everything imports fine but all i cannot change the column and row value
please guide or point me a direction
thanking you.
#include <SPI.h>
#include <SD.h>
#define CS_PIN 10
int latchPin = 8;
int clockPin = 7;
int dataPin = 6;
int row;
int roww;
int column;
const int COL_COUNT = 12; //-------------------------------------> this column i want to change from sd card.
const int ROW_COUNT = 4; //-------------------------------------> this row i want to change from sd card.
int sequence[ROW_COUNT][COL_COUNT]= {
171,25,153,149,65,192,213,229,130,162,3,12,
255,255,255,255,255,255,255,255,255,255,255,255
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
if (!SD.begin(CS_PIN)) {
("begin failed");
File dataFile = SD.open("set.txt");
if (dataFile)
char a [4] = {dataFile.read(),dataFile.read(),dataFile.read(),dataFile.read()};
int column = atoi(a);
Serial.println(column);
char b = dataFile.read(); // to forget the delimiter ","
char e [4] = {dataFile.read(),dataFile.read(),dataFile.read(),dataFile.read()};
int roww = atoi(e);
Serial.println(roww);
dataFile.close();
return (roww, column);
int COL_COUNT = column; this is want i was trying
int ROW_COUNT = roww; this is want i was trying
for (int row = 0; row < ROW_COUNT; row++)
for (int col = 0; col < COL_COUNT; col++)
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, LSBFIRST, sequence[row][4]); // deleted above 11 shift register to post
shiftOut(dataPin, clockPin, LSBFIRST, sequence[row][3]);
shiftOut(dataPin, clockPin, LSBFIRST, sequence[row][2]);
shiftOut(dataPin, clockPin, LSBFIRST, sequence[row][1]);
shiftOut(dataPin, clockPin, LSBFIRST, sequence[row][0]);
digitalWrite(latchPin, HIGH);
delay(100);
