Changing a tft library to fit my project
i have a problem with my project where i will be showing real time data on a tft and the suitable library i used turned out to support 3.0 and 3.2 tft while i am using a 3.5 tft is there is a way to change the bin connection in the library or add the needed codes to a library that support 3.5 because after i change to another Ada_fruit library the code turn into a mess
the library i am using is <TFT_HX8357>
the display is 3.5 inch tft shield (ILI9486)
i am using arduino mega 2560
#define Adresa_MCP4725 96             //DAC adress
#define pin_ADC A15                   //ADC input pin
#define pin_BAT A13                   //Battery voltage input pin
#define WHITE     0xFFFF              //color
#define BLACK     0x0000              //color
#define RED       0xF800              //color
#define GREEN     0x07E0              //color
#define DKBLUE    0x000D              //color
#define buton_sus 7
#define buton_OK 6
#define buton_jos 5
#define senzor_pas 3
#define SDC_CS 53                     //SD card control pin
#include <Wire.h>
#include <arduinoFFT.h>
#include <TFT_HX8357.h>
#include "Free_Fonts.h"
#include <SD.h>
TFT_HX8357 tft = TFT_HX8357();
arduinoFFT FFT = arduinoFFT();
File fisier;
const word nivele_bat[3] = {384, 392, 401};   //battery voltage threshold levels: low - med1 - med2 (V_bat/5V*1023*0.4)
//GPR global parameters
const double pas_deplasare_GPR = 0.24;    //GPR horizontal step [m]
const double banda = 587000000;           //GPR bandwidth [Hz]; 910 MHz - 323 MHz
const double amplitudine_maxima = 30000;  //maximum FFT module value (for scaling)
const word nr_esant = 256;                //sample no.
//menus
const char *medii_propagare[] = {"Air - 0.3 m/ns", "Ice - 0.16 m/ns", "Dry sand - 0.15 m/ns", "Dry soil (Granite) - 0.13 m/ns", "Limestone - 0.12 m/ns", "Asphalt - 0.11 m/ns", "Concrete - 0.1 m/ns", "Moist soil - 0.09 m/ns", "Wet soil (Silt) - 0.07 m/ns", "Saturated sand (Clay) - 0.06 m/ns", "Sweet water - 0.03 m/ns", "Salt water - 0.01 m/ns"};
const double viteze[] = {300000000, 160000000, 150000000, 130000000, 120000000, 110000000, 100000000, 90000000, 70000000, 60000000, 30000000, 10000000};
const word adancimi[] = {16, 32, 64, 128}; //resolution multiples
const double pasi_adanc[] = 		{10, 5, 2.5, 1, 0.5, 0.25, 0.1, 0.05, 0.025, 0.01};
const word zecimale_pasi_adanc[] =  {0,  0, 1  , 0,   1,    2,   1,    2,     3,    2};
const word distante[] = {12, 24, 48, 96};
//graph constants
const word orig_x = 60, orig_y = 290, latime_grafic = 400, inaltime_grafic = 256; //graph origin coord. and dimensions [pixels]
//variabile globale afisare grafic
double max_dist, pas_dist, max_adanc, min_adanc, pas_adanc, rezolutie; // [m]
double c; //[m/s]
word nr_cel_rez_oriz, nr_cel_rez_vert, inaltime_cel_rez, latime_cel_rez, nr_zecimale_pasi_adanc, xpos, ypos, pas = 0;
//antenna coupling correction (anechoic chamber acquisition)
//const word corectie[nr_esant] = {497, 497, 477, 383, 251, 163, 125, 113, 146, 210, 305, 430, 550, 682, 801, 893, 947, 964, 922, 787, 654, 569, 521, 486, 455, 446, 451, 454, 439, 409, 377, 352, 337, 332, 323, 334, 342, 354, 371, 384, 397, 410, 420, 433, 449, 468, 496, 528, 560, 596, 637, 674, 705, 726, 733, 735, 735, 738, 749, 757, 760, 754, 731, 699, 657, 597, 520, 432, 342, 264, 213, 180, 164, 164, 173, 194, 222, 252, 288, 316, 350, 390, 425, 459, 491, 522, 548, 571, 590, 606, 624, 642, 660, 681, 694, 703, 706, 701, 692, 676, 651, 623, 590, 557, 528, 501, 477, 457, 443, 433, 429, 429, 431, 433, 439, 449, 462, 476, 492, 508, 525, 543, 566, 587, 604, 609, 603, 589, 570, 547, 519, 482, 434, 376, 326, 277, 233, 194, 159, 147, 167, 224, 306, 383, 449, 503, 545, 576, 601, 611, 615, 616, 617, 617, 616, 614, 613, 609, 602, 593, 584, 577, 571, 566, 559, 553, 545, 539, 533, 528, 524, 521, 518, 515, 510, 505, 500, 496, 493, 490, 485, 480, 477, 475, 474, 475, 476, 479, 484, 490, 496, 502, 508, 514, 522, 532, 538, 542, 541, 540, 538, 536, 536, 534, 531, 525, 520, 511, 503, 497, 491, 487, 483, 479, 473, 467, 468, 468, 466, 466, 466, 466, 467, 467, 470, 468, 467, 467, 466, 466, 465, 465, 467, 468, 467, 468, 467, 471, 473, 475, 477, 480, 482, 484, 486, 489, 491, 494, 495, 497, 497, 498, 498, 499, 498, 498};
//global variables
word i, amplitudine_scalata, culoare, esantioane[nr_esant];
double real[nr_esant], imag[nr_esant], amplitudine_corectata_cu_dist;
boolean cont, card;
  Wire.begin();
  Wire.setClock(400000);
  tft.begin();
  tft.fillScreen(BLACK);
  tft.setRotation(1);
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
  tft.setTextDatum(TC_DATUM); // Centered
  tft.setFreeFont(FSB12);
  xpos = tft.width() / 2; // Middle screen
  ypos = (tft.height() / 2) - tft.fontHeight(GFXFF); // Middle screen
  pinMode(buton_sus, INPUT);
  pinMode(buton_OK, INPUT);
  pinMode(buton_jos, INPUT);
  pinMode(senzor_pas, INPUT);
  tft.drawString("<c> Mirel Paun 2020", xpos, ypos, GFXFF);
  if (!digitalRead(buton_OK))
    card = false; //do nor store on SD Card
    while (!digitalRead(buton_OK)) ;
    if (SD.begin(SDC_CS))
      card = true;
      tft.drawString("Waiting for PC to connect ...", xpos, ypos, GFXFF);
      tft.drawString("Press OK to continue ...", xpos, ypos + tft.fontHeight(GFXFF), GFXFF);
      while ((Serial.available() <= 0) && (digitalRead(buton_OK))) //wait for PC or OK button
        delay(100);
      if (Serial.available() > 0)
        if (Serial.read() == 'A')
          fisier = SD.open("Date.dat");
          if (fisier)
            //Send stored data
            tft.drawString("Connected. Sending file!", xpos, ypos, GFXFF);
            while (fisier.available())
              Serial.write(fisier.read());
            fisier.close();
            tft.drawString("Deleting file ...", xpos, ypos, GFXFF);
            if (SD.remove("Date.dat")) {
              tft.drawString("Deleted!", xpos, ypos + tft.fontHeight(GFXFF), GFXFF);
            else {
              tft.drawString("Error deleting file!", xpos, ypos + tft.fontHeight(GFXFF), GFXFF);
            while (1) {
              ; // Stop
            tft.drawString("Error! File missing!", xpos, ypos, GFXFF);
            while (1) {
              ; // Stop
      card = false; //no SD card
      tft.drawString("SD Card missing!!!", xpos, ypos, GFXFF);
      delay(2000);
  //DAC at 0
  Wire.beginTransmission(Adresa_MCP4725);
  Wire.write( 0 );        //MSB
  Wire.write( 0 );        //LSB
  Wire.endTransmission();
  delay(10);
  //Velocities menu--------------------------------------------------------------
  ypos = 10;
  tft.drawString("Select propagation speed c:", xpos, ypos, GFXFF);
  ypos += tft.fontHeight(GFXFF);
  tft.setFreeFont(FSB9);
  for (i = 0; i < (sizeof(medii_propagare) / sizeof(medii_propagare[0])); i++)
    tft.drawString(medii_propagare[i], xpos, ypos, GFXFF);
  i = 0;
  ypos = 34 + i * tft.fontHeight(GFXFF);
  tft.drawRect(90, ypos, 300, 22, RED); //Draw cursor
  cont = false;
  do {
    while (digitalRead(buton_sus) && digitalRead(buton_jos) && digitalRead(buton_OK)) {
      ; // wait
    delay(10);
    if (!digitalRead(buton_jos))
      if (i < (sizeof(medii_propagare) / sizeof(medii_propagare[0]) - 1)) {
        i++;
      else {
        i = 0;
      tft.drawRect(90, ypos, 300, 22, BLACK);
    else if (!digitalRead(buton_sus))
      if (i > 0) {
        i--;
      else {
        i = (sizeof(medii_propagare) / sizeof(medii_propagare[0]) - 1);
    else if (!digitalRead(buton_OK))
      c = viteze[i];
      cont = true;
  } while (!cont);
  rezolutie = c / (2.0 * banda); //depth resolution [m]
  min_adanc = -4 * rezolutie;  	 //offset cables + antennas (aprox. 4 * rezolution)
  if (card)
    //Verify file existance, if missing, create it and write speed index
    if (!SD.exists("Date.dat")) {
      fisier = SD.open("Date.dat", FILE_WRITE);
      fisier.write(highByte(i));
      fisier.write(lowByte(i));
      fisier.close();
  //Depth menu--------------------------------------------------------------
  i = 0;
  word ind_adanc_max = sizeof(adancimi) / sizeof(adancimi[0]) - 1;
  ypos = 10;
  tft.drawString("Select maximum displayed depth:", xpos, ypos, GFXFF);
  for (i = 0; i <= ind_adanc_max; i++)
    double adancime_temp = adancimi[i] * rezolutie + min_adanc;
    double zecimale = adancime_temp - floor(adancime_temp);
    String sir;
    if (zecimale < (adancime_temp / 10)) sir = String(adancime_temp, 0) + " m";
    else sir = String(adancime_temp, 1) + " m";
    char text[6];
    sir.toCharArray(text, 6);
    tft.drawString(text, xpos, ypos, GFXFF);
  i = 0;
  cont = false;
  do {
      ; // wait
    delay(10);
      if (i < ind_adanc_max) {
        i++;
      else {
        i = 0;
      if (i > 0) {
        i--;
      else {
        i = ind_adanc_max;
      nr_cel_rez_vert = adancimi[i];
      max_adanc = nr_cel_rez_vert * rezolutie + min_adanc;
      double pas_adanc_temp = (max_adanc - min_adanc) / 4;
      i = 0;
      while ((abs(pas_adanc_temp - pasi_adanc[i]) > abs(pas_adanc_temp - pasi_adanc[i + 1])) && ((i + 1) < (sizeof(pasi_adanc) / sizeof(pasi_adanc[0]) - 1)))
        i++;
      if (abs(pas_adanc_temp - pasi_adanc[i]) > abs(pas_adanc_temp - pasi_adanc[i + 1])) i++;
      pas_adanc = pasi_adanc[i];
      nr_zecimale_pasi_adanc = zecimale_pasi_adanc[i];
      cont = true;
  } while (!cont);
  //Distance menu--------------------------------------------------------------
  ypos = 10;
  tft.drawString("Select horizontal distance on screen:", xpos, ypos, GFXFF);
  for (i = 0; i < (sizeof(distante) / sizeof(distante[0])); i++)
    String sir = String(distante[i]) + " m";
    char text[5];
    sir.toCharArray(text, 5);
  i = 0;
  cont = false;
  do {
      ; // wait
    delay(10);
      if (i < (sizeof(distante) / sizeof(distante[0]) - 1)) {
        i++;
      else {
        i = 0;
      if (i > 0) {
        i--;
      else {
        i = (sizeof(distante) / sizeof(distante[0]) - 1);
      max_dist = distante[i];
      pas_dist = max_dist / 6;
      cont = true;
  } while (!cont);
  //graph parameters
  inaltime_cel_rez = inaltime_grafic / nr_cel_rez_vert;  	  				  //[pixels]
  nr_cel_rez_oriz = max_dist / pas_deplasare_GPR;
  latime_cel_rez = latime_grafic / nr_cel_rez_oriz;                   //[pixels]
  // Draw grid
  Graph(tft, orig_x, orig_y, latime_grafic, inaltime_grafic, 0, max_dist, pas_dist, min_adanc, max_adanc, pas_adanc, "GPR", "Distance [m]", "Depth [m]");
  afis_card();
  masurare_afis_bat();
  // Wait for step wheel signal
  while (digitalRead(senzor_pas) == 0)
  while (digitalRead(senzor_pas) == 1)
  // If screen is full, delete and start again
  if (((pas % nr_cel_rez_oriz) == 0) && (pas != 0))
    word nr_ecran = pas / nr_cel_rez_oriz;
    Graph(tft, orig_x, orig_y, latime_grafic, inaltime_grafic, nr_ecran * max_dist, (nr_ecran + 1) * max_dist, pas_dist, min_adanc, max_adanc, pas_adanc, "GPR", "Distance [m]", "Depth [m]");
    afis_card();
  // Generate modulation signal and sample radar echo
  for (i = 0; i <= 4080; i = i + 16) // DAC goes from 0 - 4.98V
    // Write to DAC
    Wire.write( highByte(i) );        //MSB
    Wire.write( lowByte(i) );         //LSB
    // Read from ADC
    esantioane[i >> 4] = analogRead(pin_ADC); // >>4 means /16
  //Bring DAC to 0
  //Store on SD Card
  if (card)
    for (i = 0; i < nr_esant; i++)
      fisier.write(highByte(esantioane[i]));
      fisier.write(lowByte(esantioane[i]));
    fisier.close();
  // Prepare data for FFT
    //real[i] = (double)(esantioane[i]) - (double)(corectie[i]); // Load samples and correct antenna coupling
    real[i] = (double)(esantioane[i]) - 512.0;    // Load samples and remove d.c.
    imag[i] = 0.0;                                // Delete imaginary part
  // Compute FFT
  FFT.Compute(real, imag, nr_esant, FFT_FORWARD); //FFT
  FFT.ComplexToMagnitude(real, imag, nr_esant);   //Compute FFT and store it in real
  //Draw one column
  for (i = 0; i < nr_cel_rez_vert; i++)
    if(i <= 40) amplitudine_corectata_cu_dist = real[i] * exp(i * 0.1);   // distance correction
    else amplitudine_corectata_cu_dist = real[i] * 54.598;                // distance correction
    amplitudine_scalata = (word)(amplitudine_corectata_cu_dist * 255.0 / amplitudine_maxima);
    if (amplitudine_scalata > 255) amplitudine_scalata = 255;
    culoare = (((amplitudine_scalata & 0b11111000) << 8) + ((amplitudine_scalata & 0b11111100) << 3) + (amplitudine_scalata >> 3));
    tft.fillRect(orig_x + 1 + pas % nr_cel_rez_oriz * latime_cel_rez, orig_y + 1 - inaltime_grafic + i * inaltime_cel_rez, latime_cel_rez, inaltime_cel_rez, culoare);
  pas++;
// Grid drawing routine
void Graph(TFT_HX8357 &tft, double gx, double gy, double w, double h,
           double xlo, double xhi, double xinc,
           double ylo, double yhi, double yinc,
           char *title, char *xlabel, char *ylabel)
  double ydiv, xdiv;
  double i;
  double temp;
  int rot, newrot;
  unsigned int gcolor = DKBLUE; //grid color
  unsigned int acolor = RED;    //axis color
  unsigned int tcolor = WHITE;  //text color
  unsigned int bcolor = BLACK;  //background color
  tft.setFreeFont(NULL); //------------------------
  tft.setTextDatum(MR_DATUM);
  // draw x axis
  tft.drawLine(gx, gy - h, gx + w, gy - h, acolor);  //red axis
  tft.setTextColor(acolor, bcolor);
  tft.drawString(xlabel, (int)(gx + w) , (int)(gy - h) - 5, 2);
  // draw origin
  tft.setTextColor(tcolor, bcolor);
  tft.drawFloat(ylo, 3, gx - 4, gy - h, 1);
  for (i = 0; i <= yhi; i += yinc)
    temp =  gy - h + (i - ylo) * h / (yhi - ylo);
    tft.drawLine(gx, temp, gx + w, temp, gcolor);
    // draw y axis labels
    tft.drawFloat(i, nr_zecimale_pasi_adanc, gx - 4, temp, 1);
  tft.drawLine(gx, gy, gx + w, gy, gcolor);//graph bottom line
  // draw y axis
  for (i = xlo; i <= xhi; i += xinc)
    temp =  (i - xlo) * w / (xhi - xlo) + gx;
    if (i == xlo) 									//red axis
      tft.drawLine(temp, gy, temp, gy - h, acolor);
      tft.setTextDatum(BC_DATUM);
      tft.drawString(ylabel, (int)temp, (int)(gy - h - 8) , 2);
      tft.drawLine(temp, gy, temp, gy - h + 1, gcolor);
    //draw x axis labels
    tft.drawNumber(i, temp, gy + 7, 1);
  //draw graph label
  tft.drawString(title, (int)(gx + w / 2) , (int)(gy - h - 30), 4);
void afis_card()
  if (card)
    tft.setTextColor(GREEN, BLACK);
    tft.drawString("CARD OK", 370, 2, 2);
    tft.setTextColor(RED, BLACK);
    tft.drawString("NO CARD", 370, 2, 2);
void masurare_afis_bat(void)
  //Measure and display battery state
  word val = analogRead(pin_BAT);
  if (val <= nivele_bat[0]) // low
    tft.drawRect(430, 5, 20, 12, RED);
    tft.drawRect(431, 6, 18, 10, RED);
    tft.fillRect(450, 7, 3, 8, RED);
    tft.fillRect(432, 7, 16, 8, BLACK);
  else if (val <= nivele_bat[1]) // med1
    tft.drawRect(430, 5, 20, 12, WHITE);
    tft.fillRect(450, 7, 3, 8, WHITE);
    tft.fillRect(432, 7, 5, 8, WHITE);
    tft.fillRect(437, 7, 11, 8, BLACK);
  else if (val <= nivele_bat[2]) // med2
    tft.fillRect(432, 7, 11, 8, WHITE);
    tft.fillRect(443, 7, 5, 8, BLACK);
  else // max
    tft.fillRect(430, 5, 20, 12, WHITE);
For informed help, please read and follow the instructions in the "How to get the best out of this forum" post, linked at the head of every forum category.
The library you are using wont know or care about the physical size of the display.
What does make a differance is the resolution of the display, is it 160x120 pixels or 320x240 pixels etc.
probably it define the pins in the library and both sizes use different pins and i think both have the same resolution
sorry for the missing data i am new to the form and i am a bit lost
The main problem is the different chips of the two displays ( not its size ). You need a library for the ILI9486 chip.
the hx8357 library offer a ili9486 support but even after i changed the driver it still didn't work
