changing analog pins data logging using sdFat library
Hey Guys : )
background:
my goal is to use sdFat library, more precisely AnalogBinLogger example.
I want to log data from changing analog pins for example, I want to log from pin 0 to pin 3 for 5 minutes and then from pin 4 to pin 6 for another 5 mins and then from pin 7 to pin 9 for another 5 mins. that is going to be continuously which means I am going to get rid of the part where you have to enter r for start logging.
regarding the time, I managed to figure it out, I am just using the value of the variable count, if my sampling rate is 1000 samples/sec for example then 5 minutes will be 1000605
and the change will be done in this line:
 if (Serial.available()) {
      // Stop ISR calls.
      adcStop();
to
if (count >1000*60*5) {
      // Stop ISR calls.
      adcStop();
and this worked fine,
my problem is with the changing pins:
const uint8_t PIN_LIST[] = {1};
I changed this line to
uint8_t PIN_LIST[3] = {};
first I removed the word const, because its not going to be constant anymore, and I just declared an empty array, and second I am changing the pins in the loop
here is the loop after I got rid of doing the serial input:
void loop(void) {
// discard any input
int i;
for (i=0;i<=12;i+3)
PIN_LIST[] = {i,i+1,i+2};
  logData();
  Serial.println("done");
the problem is I get this error :
AnalogBinLogger.ino: In function ‘void loop()’:
AnalogBinLogger:808: error: expected primary-expression before ‘]’ token
AnalogBinLogger:808: error: expected primary-expression before ‘{’ token
AnalogBinLogger:808: error: expected `;’ before ‘{’ token
the line 808 is:
PIN_LIST = {i,i+1,i+2};
so this is the only error, any help please
n case someone has the same problem it seems like after you initialize an array this way
you won’t be able to assign all the values at once:
instead you assign each individual value
PIN_LIST[0] = i;
PIN_LIST[1] = i+1;
PIN_LIST[2] = i+2;
and now it worked : )
