Changing clock speed
I am building a project whch does not need much speed or accurate. Then I decided to avoid the use of the crystal and program the atmega with 8Mhz internal oscilator.
In order to use the same program as with a normal arduino, I only programmed the fuses and bootloader as indicated in the arduino to breadboard tutorial, but added the board definition to the list of Arduino, in order to continue using the normal pin names.
My problem is that the compiler seems to asume the clock speed is 16Mhz because the times are double of the programmed. Un the data I added, I indicated "atmega328bb.build.f_cpu=8000000L".
¿Is there anything more that I need change or the libraries are made only for 16Mhz?
The section I added is this:
atmega328.name=Arduino ATmega328 8 MHz internal clock
atmega328.upload.protocol=arduino
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xDA
atmega328bb.bootloader.extended_fuses=0x05
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.bootloader.unlock_bits=0x3F
atmega328.bootloader.path=atmega
atmega328bb.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
atmega328.build.mcu=atmega328p
atmega328.build.core=arduino
atmega328.build.variant=standard
Be aware that the internal oscillator might not be accurate enough for the bootloader's serial communications to work correctly (or so I've heard)
If you are programming using ICSP this isn't an issue (although its a little complicated (and slow) to upload sketches via ICSP).
MarkT:
Up to now, the few uploads I made worked OK.
