Hello everyone,
I am working on a project that uses a BNO055 for orientation on a rocket. The code has a PID controller implemented for thrust vector control. Anyway, I have been frantically searching the internet for a BNO055, but it would appear that no body sells them anymore. I was wondering if someone could help me "replace" the BNO055 code, so that it would work with a MPU6050.
I have the code below:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <math.h>
#include <Servo.h>
#include <Adafruit_BMP280.h>
int P1=23;
int P2=22;
int P3=17;
int P4=16;
int P5=15;
int P6=14;
Adafruit_BMP280 bmp; // I2C
Servo pitchServo;
Servo rollServo;
float startAltitude = 0;
float altitudeAGL = 0;
float lastAltitude;
float q0;
float q1;
float q2;
float q3;
//Change sensitivity of PID controller here!!!!//
float k1=.5; //P//
float k3=.001 //I//
float k2=70; //D//
int milliOld;
int milliNew;
int dt;
float rollTarget=0;
float rollActual;
float rollError=0;
float rollErrorOld;
float rollErrorChange;
float rollErrorSlope=0;
float rollErrorArea=0;
float rollServoVal=90;
float pitchTarget=0;
float pitchActual;
float pitchError=0;
float pitchErrorOld;
float pitchErrorChange;
float pitchErrorSlope=0;
float pitchErrorArea=0;
float pitchServoVal=90;
#define BNO055_SAMPLERATE_DELAY_MS (100)
Adafruit_BNO055 myIMU = Adafruit_BNO055();
Serial.println(F("BMP280 test"));
if (!bmp.begin()) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring / I2C address"));
while (true) yield();
/* Default settings from datasheet. */
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. */
Adafruit_BMP280::SAMPLING_X2, /* Temp. oversampling */
Adafruit_BMP280::SAMPLING_X16, /* Pressure oversampling */
Adafruit_BMP280::FILTER_X16, /* Filtering. */
Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
startAltitude = bmp.readAltitude(1013.25);
myIMU.begin();
int8_t temp=myIMU.getTemp();
myIMU.setExtCrystalUse(true);
rollServo.attach(6);
pitchServo.attach(5);
rollServo.write(rollServoVal);
delay(20);
pitchServo.write(pitchServoVal);
delay(20);
milliNew=millis();
Serial.print(F("Relative altitude = "));
Serial.print(bmp.readAltitude(1013.25) - startAltitude); // approximative
Serial.println(" m");
altitudeAGL=bmp.readAltitude(1013.25)-startAltitude;
if (altitudeAGL-lastAltitude <= -2) //Checks to see if altitude has dropped by 2
{digitalWrite P1, HIGH
uint8_t system, gyro, accel, mg = 0;
myIMU.getCalibration(&system, &gyro, &accel, &mg);
imu::Quaternion quat=myIMU.getQuat();
q0=quat.w();
q1=quat.x();
q2=quat.y();
q3=quat.z();
rollActual=atan2(2*(q0*q1+q2*q3),1-2*(q1*q1+q2*q2));
pitchActual=asin(2*(q0*q2-q3*q1));
rollActual=rollActual/(2*3.141592654)*360;
pitchActual=pitchActual/(2*3.141592654)*360;
milliOld=milliNew;
milliNew=millis();
dt=milliNew-milliOld;
rollErrorOld=rollError;
rollError=rollTarget-rollActual;
rollErrorChange=rollError-rollErrorOld;
rollErrorSlope=rollErrorChange/dt;
rollErrorArea=rollErrorArea+rollError*dt;
pitchErrorOld=pitchError;
pitchError=pitchTarget-pitchActual;
pitchErrorChange=pitchError-pitchErrorOld;
pitchErrorSlope=pitchErrorChange/dt;
pitchErrorArea=pitchErrorArea+pitchError*dt;
rollServoVal=rollServoVal+k1*rollError+k2*rollErrorSlpoe+k3*rollErrorArea;
pitchServoVal=pitchServoVal+k1*pitchError+k2*pitchErrorSlope+k3*pitchErrorArea;
Serial.print(rollTarget);
Serial.print(",");
Serial.print(rollActual);
Serial.print(",");
Serial.print(pitchTarget);
Serial.print(",");
Serial.print(pitchActual);
Serial.print(",");
Serial.print(accel);
Serial.print(",");
Serial.print(gyro);
Serial.print(",");
Serial.print(mg);
Serial.print(",");
Serial.println(system);
delay(BNO055_SAMPLERATE_DELAY_MS);
