Hello I'm trying to recreate this simple project but I'm using different components. I've followed the first few steps of getting my components wired together and formatting my audio and video files. However, I'm lost when it comes to code. In the instructions it states to change their chosen display/microsd ("ILI9225") to my chosen one but since my components are separate how do I go about doing this? What other changes do I need to make? Comments about what lines of code do is extremely helpful as I used to code Visual Basic a long time ago so (hopefully) my understanding of it will come back to me if someone explains it well haha.
Also I know I need different libraries than what they used and I'll list what I have installed:
For OLED - "Adafruit GFX" and "Adafruit SSD1327"
For Audio - "Adafruit Zero I2S"
Nothing for MicroSD
I have my board set to "Seeeduino XIAO"
Here's my components:
Adafruit Grayscale OLED
Amplifier Mono+(connected to speaker)
MicroSD Breakout Board+
Seeeduino XIAO
Here's the code:
#include <Adafruit_SSD1327.h>
#include <splash.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_GrayOLED.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#define AUDIO_FILENAME "/44100_u16le.pcm"
#define FPS 30
#define MJPEG_FILENAME "/220_30fps.mjpeg"
#define MJPEG_BUFFER_SIZE (220 * 176 * 2 / 4)
//#define FPS 15
//#define MJPEG_FILENAME "/320_15fps.mjpeg"
//#define MJPEG_BUFFER_SIZE (320 * 240 * 2 / 4)
#define READ_BUFFER_SIZE 2048
* Connect the SD card to the following pins:
* SD Card | ESP32
* D2 12
* D3 13
* CMD 15
* VSS GND
* VDD 3.3V
* CLK 14
* VSS GND
* D0 2 (add 1K pull up after flashing)
* D1 4
#include <WiFi.h>
#include <SD_MMC.h>
#include <driver/i2s.h>
#include <Arduino_GFX_Library.h>
#define TFT_BRIGHTNESS 128
// ST7789 Display
// #define TFT_BL 32
// Arduino_ESP32SPI *bus = new Arduino_ESP32SPI(27 /* DC */, 5 /* CS */, 18 /* SCK */, 23 /* MOSI */, 19 /* MISO */);
// Arduino_GFX *gfx = new Arduino_ST7789(bus, 33 /* RST */, 3 /* rotation */, true /* IPS */);
// ILI9225 Display
#define TFT_BL 22
Arduino_GFX *gfx = new Arduino_ILI9225(bus, 33 /* RST */, 3 /* rotation */);
// ILI9341 Display
// #define TFT_BL 22
// Arduino_GFX *gfx = new Arduino_ILI9341(bus, 33 /* RST */, 3 /* rotation */);
#include "MjpegClass.h"
static MjpegClass mjpeg;
int next_frame = 0;
int skipped_frames = 0;
unsigned long total_read_audio = 0;
unsigned long total_play_audio = 0;
unsigned long total_read_video = 0;
unsigned long total_play_video = 0;
unsigned long total_remain = 0;
unsigned long start_ms, curr_ms, next_frame_ms;
WiFi.mode(WIFI_OFF);
// Init Video
gfx->begin();
gfx->fillScreen(BLACK);
#ifdef TFT_BL
ledcAttachPin(TFT_BL, 1); // assign TFT_BL pin to channel 1
ledcSetup(1, 12000, 8); // 12 kHz PWM, 8-bit resolution
ledcWrite(1, TFT_BRIGHTNESS); // brightness 0 - 255
#endif
// Init SD card
// if ((!SD_MMC.begin()) && (!SD_MMC.begin())) /* 4-bit SD bus mode */
if ((!SD_MMC.begin("/sdcard", true)) && (!SD_MMC.begin("/sdcard", true))) /* 1-bit SD bus mode */
Serial.println(F("ERROR: SD card mount failed!"));
gfx->println(F("ERROR: SD card mount failed!"));
// Init Audio
i2s_config_t i2s_config_dac = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN),
.sample_rate = 44100,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
.communication_format = (i2s_comm_format_t)(I2S_COMM_FORMAT_PCM | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1, // lowest interrupt priority
// .dma_buf_count = 5,
.dma_buf_count = 8,
.dma_buf_len = 490,
.use_apll = false,
Serial.printf("%p\n", &i2s_config_dac);
if (i2s_driver_install(I2S_NUM_0, &i2s_config_dac, 0, NULL) != ESP_OK)
Serial.println(F("ERROR: Unable to install I2S drives!"));
gfx->println(F("ERROR: Unable to install I2S drives!"));
i2s_set_pin((i2s_port_t)0, NULL);
i2s_set_dac_mode(I2S_DAC_CHANNEL_RIGHT_EN);
i2s_zero_dma_buffer((i2s_port_t)0);
File aFile = SD_MMC.open(AUDIO_FILENAME);
if (!aFile || aFile.isDirectory())
Serial.println(F("ERROR: Failed to open " AUDIO_FILENAME " file for reading!"));
gfx->println(F("ERROR: Failed to open " AUDIO_FILENAME " file for reading!"));
File vFile = SD_MMC.open(MJPEG_FILENAME);
if (!vFile || vFile.isDirectory())
Serial.println(F("ERROR: Failed to open " MJPEG_FILENAME " file for reading"));
gfx->println(F("ERROR: Failed to open " MJPEG_FILENAME " file for reading"));
uint8_t *aBuf = (uint8_t *)malloc(2940);
// uint8_t *aBuf = (uint8_t *)malloc(5880);
if (!aBuf)
Serial.println(F("aBuf malloc failed!"));
uint8_t *mjpeg_buf = (uint8_t *)malloc(MJPEG_BUFFER_SIZE);
if (!mjpeg_buf)
Serial.println(F("mjpeg_buf malloc failed!"));
Serial.println(F("PCM audio MJPEG video start"));
start_ms = millis();
curr_ms = millis();
mjpeg.setup(vFile, mjpeg_buf, (Arduino_TFT *)gfx, true);
next_frame_ms = start_ms + (++next_frame * 1000 / FPS);
// prefetch first audio buffer
aFile.read(aBuf, 980);
i2s_write_bytes((i2s_port_t)0, (char *)aBuf, 980, 0);
while (vFile.available() && aFile.available())
// Read audio
aFile.read(aBuf, 2940);
// aFile.read(aBuf, 5880);
total_read_audio += millis() - curr_ms;
curr_ms = millis();
// Play audio
i2s_write_bytes((i2s_port_t)0, (char *)(aBuf + 980), 980, 0);
i2s_write_bytes((i2s_port_t)0, (char *)(aBuf + 1960), 980, 0);
// // for 15 FPS
// i2s_write_bytes((i2s_port_t)0, (char *)(aBuf + 2940), 980, 0);
// i2s_write_bytes((i2s_port_t)0, (char *)(aBuf + 3920), 980, 0);
// i2s_write_bytes((i2s_port_t)0, (char *)(aBuf + 4900), 980, 0);
total_play_audio += millis() - curr_ms;
curr_ms = millis();
// Read video
mjpeg.readMjpegBuf();
total_read_video += millis() - curr_ms;
curr_ms = millis();
if (millis() < next_frame_ms) // check show frame or skip frame
// Play video
mjpeg.drawJpg();
total_play_video += millis() - curr_ms;
int remain_ms = next_frame_ms - millis();
total_remain += remain_ms;
if (remain_ms > 0)
delay(remain_ms);
++skipped_frames;
Serial.println(F("Skip frame"));
curr_ms = millis();
int time_used = millis() - start_ms;
Serial.println(F("PCM audio MJPEG video end"));
vFile.close();
aFile.close();
int played_frames = next_frame - 1 - skipped_frames;
float fps = 1000.0 * played_frames / time_used;
Serial.printf("Played frames: %d\n", played_frames);
Serial.printf("Skipped frames: %d (%0.1f %%)\n", skipped_frames, 100.0 * skipped_frames / played_frames);
Serial.printf("Time used: %d ms\n", time_used);
Serial.printf("Expected FPS: %d\n", FPS);
Serial.printf("Actual FPS: %0.1f\n", fps);
Serial.printf("SDMMC read PCM: %d ms (%0.1f %%)\n", total_read_audio, 100.0 * total_read_audio / time_used);
Serial.printf("Play audio: %d ms (%0.1f %%)\n", total_play_audio, 100.0 * total_play_audio / time_used);
Serial.printf("SDMMC read MJPEG: %d ms (%0.1f %%)\n", total_read_video, 100.0 * total_read_video / time_used);
Serial.printf("Play video: %d ms (%0.1f %%)\n", total_play_video, 100.0 * total_play_video / time_used);
Serial.printf("Remain: %d ms (%0.1f %%)\n", total_remain, 100.0 * total_remain / time_used);
#define CHART_MARGIN 24
#define LEGEND_A_COLOR 0xE0C3
#define LEGEND_B_COLOR 0x33F7
#define LEGEND_C_COLOR 0x4D69
#define LEGEND_D_COLOR 0x9A74
#define LEGEND_E_COLOR 0xFBE0
#define LEGEND_F_COLOR 0xFFE6
#define LEGEND_G_COLOR 0xA2A5
gfx->setCursor(0, 0);
gfx->setTextColor(WHITE);
gfx->printf("Played frames: %d\n", played_frames);
gfx->printf("Skipped frames: %d (%0.1f %%)\n", skipped_frames, 100.0 * skipped_frames / played_frames);
gfx->printf("Actual FPS: %0.1f\n\n", fps);
int16_t r1 = ((gfx->height() - CHART_MARGIN - CHART_MARGIN) / 2);
int16_t r2 = r1 / 2;
int16_t cx = gfx->width() - gfx->height() + CHART_MARGIN + CHART_MARGIN - 1 + r1;
int16_t cy = r1 + CHART_MARGIN;
float arc_start = 0;
float arc_end = max(2.0, 360.0 * total_read_audio / time_used);
for (int i = arc_start + 1; i < arc_end; i += 2)
gfx->fillArc(cx, cy, r1, r2, arc_start - 90.0, i - 90.0, LEGEND_D_COLOR);
gfx->fillArc(cx, cy, r1, r2, arc_start - 90.0, arc_end - 90.0, LEGEND_D_COLOR);
gfx->setTextColor(LEGEND_D_COLOR);
gfx->printf("Read PCM:\n%0.1f %%\n", 100.0 * total_read_audio / time_used);
arc_start = arc_end;
arc_end += max(2.0, 360.0 * total_play_audio / time_used);
gfx->fillArc(cx, cy, r1, r2, arc_start - 90.0, i - 90.0, LEGEND_C_COLOR);
gfx->fillArc(cx, cy, r1, r2, arc_start - 90.0, arc_end - 90.0, LEGEND_C_COLOR);
gfx->setTextColor(LEGEND_C_COLOR);
gfx->printf("Play audio:\n%0.1f %%\n", 100.0 * total_play_audio / time_used);
arc_end += max(2.0, 360.0 * total_read_video / time_used);
gfx->fillArc(cx, cy, r1, r2, arc_start - 90.0, i - 90.0, LEGEND_B_COLOR);
gfx->fillArc(cx, cy, r1, r2, arc_start - 90.0, arc_end - 90.0, LEGEND_B_COLOR);
gfx->setTextColor(LEGEND_B_COLOR);
gfx->printf("Read MJPEG:\n%0.1f %%\n", 100.0 * total_read_video / time_used);
arc_end += max(2.0, 360.0 * total_play_video / time_used);
gfx->fillArc(cx, cy, r1, 0, arc_start - 90.0, i - 90.0, LEGEND_A_COLOR);
gfx->fillArc(cx, cy, r1, 0, arc_start - 90.0, arc_end - 90.0, LEGEND_A_COLOR);
gfx->setTextColor(LEGEND_A_COLOR);
gfx->printf("Play video:\n%0.1f %%\n", 100.0 * total_play_video / time_used);
i2s_driver_uninstall((i2s_port_t)0); //stop & destroy i2s driver
// avoid unexpected output at audio pins
pinMode(25, OUTPUT);
digitalWrite(25, LOW);
pinMode(26, OUTPUT);
digitalWrite(26, LOW);
#ifdef TFT_BL
delay(60000);
ledcDetachPin(TFT_BL);
#endif
// gfx->displayOff();
// esp_deep_sleep_start();
