Changing Config parameter in Serial.begin
I am getting an error when I try to do the below thing.
String mconfig = “SERIAL_8E1”;
Serial.begin(9600,mconfig);
error I get is “no matching function for call to ‘HardwareSerial::begin(int&, String&)’”
I am using ESP8266.
Thanks
Right. Because SERIAL_8E1 is not a string, it is a defined constant. What are you trying to do by passing mconfig? You can dig into the serial code and find the defined type of SERIAL_8E1 or the second parameter of begin(), then you can define mconfig as a variable of that type.
It says its a string, am I understanding it wrong ?
Hardwareserial.cpp
Hardwareserial.h
Thanks
I_think:
Where are you seeing that? I don't see anything like that at those links. Here is the function signature:
void begin(unsigned long baud, SerialConfig config)
So ,how should I do ?
I want to dynamically change configuration. say from SERIAL_8N1 to SERIAL_7E1, or some other which user wants to configure.
Thanks
give the user the option to choose one element of the enumeration SerialConfig
https://github.com/esp8266/Arduino/blob/007e495e0d88eabc6dae31fad311df38f8914607/cores/esp8266/HardwareSerial.h#L35
and handover the CONTENT of the chosen option to
not the name of the choosen enumeration!
i.e. on a webpage let the user choose from a html select-tag.
<select id="config">
  <option value="42">7E1</option>
  <option value="9">8E1</option>
42 and 9 are just example numbers, you will print them to your html with the enumeration anyway.
If my answer is not clear enough, make a SMALL compileable sketch showing your option setting and we might give a more detailed answer.
Please If you could help with example sketch. I am not using HTML. I will receive setting as an mqtt message.
Thanks.
I'm not using mqtt.
come up with a sketch where you receive a variable byte mconfig; and then use a switch case.
I_think:
Thanks
I already told you what to do...
SerialConfig mconfig;
mconfig = SERIAL_8E1;
noiasca:
I’m not using mqtt.
I am using a temporary code to solve the purpose. but is looking for something right way to do. here is it
  if ( SerConfig == "8N1"){ Serial.begin(_BaudRate,SERIAL_8N1);}
  if ( SerConfig == "8E1"){ Serial.begin(_BaudRate,SERIAL_8E1);}
  if ( SerConfig == "8O1"){ Serial.begin(_BaudRate,SERIAL_8O1);}
  if ( SerConfig == "8N2"){ Serial.begin(_BaudRate,SERIAL_8N2);}
  if ( SerConfig == "8E2"){ Serial.begin(_BaudRate,SERIAL_8E2);}
  if ( SerConfig == "8O2"){ Serial.begin(_BaudRate,SERIAL_8O2);}
  if ( SerConfig == "7N1"){ Serial.begin(_BaudRate,SERIAL_7N1);}
  if ( SerConfig == "7E1"){ Serial.begin(_BaudRate,SERIAL_7E1);}
  if ( SerConfig == "7O1"){ Serial.begin(_BaudRate,SERIAL_7O1);}
  if ( SerConfig == "7N2"){ Serial.begin(_BaudRate,SERIAL_7N2);}
  if ( SerConfig == "7E2"){ Serial.begin(_BaudRate,SERIAL_7E2);}
  if ( SerConfig == "7O2"){ Serial.begin(_BaudRate,SERIAL_7O2);}
Really, you are still looking for the right way to do it? Did you read reply #8?
Where does SerConfig come from, by the way?
aarg:
That was a reply to previous. The forum rules are blocking me for posting messages. I have to wait for sometime before I post next (reply to you).
I will check and reply.
OK
So mqtt message gives me a string for setting eg. "8N1".
Which I store in string SerConfig.
