I am building an OSC music controller using the CNMAT osc library.
I am trying to change or point to a different const char * array with different button presses, namely the _address in line 36 here:
So using that library, I have a function that runs when I press a button that looks like this:
void noteOn(char *FSR_OSC_Msg, int OSC_Velocity){
OSCMessage msg(FSR_OSC_Msg);
msg.add(1);
msg.add(OSC_Velocity);
Udp.beginPacket(outIp, outPort);
msg.send(Udp);
Udp.endPacket();
msg.empty();
The FSR_OSC_Msg array is what I'm trying to control.
Each button sends osc messages with addresses like "/1/1", "/1/2", "/1/3", etc..
But I want to press a different set of buttons , and the leading 1 changes to 2, like : "/2/1", "/2/2", "/2/3", etc...
This is so I can change what messages the first set of buttons send, with a different set of buttons.
I tried creating a char array for the first part of the address:
char OSC_Msg_Prefix[32] = "/1/";
And then doing this to copy that and use the index of the buttons I'm looping through, to make an address that looks like /1/1 for group 1/button 1 for example:
//new array for new address
char FSR_OSC_Msg[32];
//get array length
size_t destination_size = sizeof (OSC_Msg_Prefix);
//set prefix to new address
strncpy(OSC_Msg_Prefix, FSR_OSC_Msg, 32);
//null terminate string
OSC_Msg_Prefix[destination_size -1] = '\0';
//new array for the fsr button number
char FSR_number[32];
//change index int to char
sprintf(FSR_number, "%d", index);
//concat prefix and button number into final address
strcat(FSR_OSC_Msg, FSR_number);
I was then hoping to use
strncpy(OSC_Msg_Prefix,"/2/",32);
for example, on another button press, to change the address.
When i Serial.write() the address, I get stuff like this:
ÐÚÿ?357357151
Can anyone please help me out?
Is there a better way to do this with pointers?
Basically I just want to be able to control that address string. And I would like for the button number to come from the index number of the button.
Sorry for the broken up code, but the real code is really long and includes lots of libraries. Here's a more full picture that I tried to simplify, stripping out how the actual buttons work, etc...:
//Open Sound Control (OSC) library for the ESP8266
#include <WiFiUdp.h>
#include <OSCMessage.h>
char ssid[] = "ssid"; // your network SSID (name)
char pass[] = "password";
WiFiUDP Udp; // A UDP instance to let us send and receive packets over UDP
const IPAddress outIp(192, 168, 0, 1); // remote IP of your computer
const unsigned int outPort = 8001; // remote port to receive OSC
const unsigned int localPort = 9000; // local port to listen for OSC packets (actually not used for sending)
int threshold = 20;
int number_of_FSR =4;
//Loop through each pin and call the FSR handler
for (int i = 0; i<number_of_FSR; i++)
handleFSR(i);
void handleFSR(int index)
//read FSR value
int val = analogRead(index);
int last_value = 0;
//===========Send a NOTE ON message if the given pad is currently off
if (val>threshold)
//send a single note on for value greater than 0
noteOn(FSR_OSC_Msg, val);
//===========Send a NOTE OFF message if the given pad is currently on
if (val == 0)
//send a single note off for velocity of 0
noteOff(FSR_OSC_Msg);
msg.add(1);
msg.send(Udp);
Udp.endPacket();
msg.empty();
void noteOff(char *FSR_OSC_Msg){
msg.add(0);
msg.add(0);
msg.send(Udp);
Udp.endPacket();
msg.empty();
