I have a program I wrote for an Arduino Uno (16MHZ) that I would like to implement on my feather (48MHZ), but I haven't been able to find a way to change the CPU clock speed. Is this something that can be done through any general software commands?
Why do you want to change the clock speed?
Why do you think you need to change the CPU clock speed?
They are completely different CPUs (AVR and ARM Cortex-M0) - so there is no direct relation between the clock speeds.
It would make implementation of my previous code easier. It involves lots of timers and interrupts. I would have to redo all the register commands that I had done because of the higher clock frequency. The register prescalar values wont work with 48MHZ as opposed to 16MHZ.
If there is an easier way of going about this issue that you can think of, I am also all ears.
All the timers are different on those processors. Nothing intended for specific Arduino Uno hardware will work on the Feather.
For informed advice, post the code, using code tags.
Here is all my code for the portions that have to do with the timers. Hopefully this is the right format to post if not sorry for inconvenience I'm new. Basically I'm wondering if the best way to go about this would just be to restart this portion of the code with the 48MHZ CPU frequency in mind.
//setup timer1 to FASTPWM on pin 10
TCCR1A=0B00100011;
TCCR1B=0B00011001;
//perform measurement of delay of the trailing edge
long int meas(int period, int minlen, int maxlen, int steplen, int nloop){
long int sum=0;
int nmiss=0;
OCR1A=period; //set the period
TIFR1 |= 0B00000001; //clear the timer overflow bit
for(int iloop=0; iloop<nloop; iloop++){
for (int len=minlen; len<maxlen; len+=steplen){
OCR1B=len; //set the pulselength
while ((TIFR1 & 0B00000001) == 0); //wait for timer overflow
while (TCNT1<(period-cycles)); //wait till pulse is almost finished
if( (TIFR1&0B00100000) !=0){ //check if trailing edge has been detected
sum+=(ICR1-len);
TIFR1 |= 0B00100000; //clear the input capture flag
nmiss++;
//update phase
phase+=absdiff;
//blink and click when phase rolls through
if(phase>phasemax){
phase-=phasemax;
LEDcycle=LEDcycles;
PORTB=(PORTB|0B00100000); //switch on LED
PORTB=(PORTB^0B00010000); //invert sound pin - click!
//switch off LED when it's been on long enough
if(LEDcycle>0){
LEDcycle--;
if(LEDcycle==0)PORTB=(PORTB&(!0B00100000));
if (nmiss>0)sum=0; //invalidate the result if there have been missing pulses
return sum;
They are completely different chips, with completely different timers & completely different registers - you will have to redo them all anyhow!
That code must be completely rewritten for the Feather. You will need to study the data sheet of the Feather to see what is possible and how to go about it.
There are ways of making the measurement that are not hardware specific.
Sounds good, thanks.
Again, it's not just the clock frequency that's different - that's the least of your worries!
The entire timer hardware is completely different - the code is just not portable at all.
