Changing default rx/tx pins for serial communicati
I have a project where i need to read parallel a 8 bit data. I was initially using different pins and a bit of code to do this now I’m thinking of using Port Manipulation however i see that only PORT D provides access to 8 bits now of these pins 0 & 1 are configured for Serial Port. Can I change this? say can i configure pins 12,13 as rx, tx and connect them to my serial port using an rs232 cable? will this create any errors? and can i simply change the destination port to the rs232 port and monitor the serial data? i’m planning to use the NewSoftSerial library on a Diecimila with an Atmega168 on Win XP
cheers,
Pracas
No. The ATmega’s UART is hardwired to those pins.
You may be able to use software serial (or new software serial), though, to bit-bang your serial port.
You could probably use the high 6 bits of port D and the low 2 of port B (arduino pins 2-9), and do a couple of bit shifts to roll it into a single byte. Not as clean as what you want, but keeps the hardware UART free…
-j
and i forgot i would need a converter between the rx/tx and the rs232! … but i suppose if i sacrifice serial communication i can get 8bit access.
have you looked into instead using the 74HC165 for this? I imagine that would be easier and give some flexibility as far using remaining pins for future ideas.
even if you want to read each of the 8 bits as a separate variable, this code can be modified to read and store bits instead of bytes.
yes i have used it. i know i cna use shift registers but was looking to explore direct to arduino possibilities.
