Hi
I can change the frequency by changing manually value if " f " but cant do that using the buttons, how to fix it ?
#include <libmaple/dma.h>
#include <LiquidCrystal.h>
//LiquidCrystal lcd(PB9,PA11,PB15,PB14,PB13,PB12);
LiquidCrystal lcd(PB9, PC14, PB15, PB14, PB13, PB12);
#define SAMPLES_TX 64
#define dt (1.0/SAMPLES_TX)
#define F(x)(0.5*(1+sin(TWO_PI*x)))
HardwareTimer Timer_4(4);
HardwareTimer Timer_2(2);
HardwareTimer Timer_3(3);
int f;
int Sound_schem = 0;
int Faza_b;
unsigned int micros_1, micros_2;
unsigned int millis_1, millis_2;
int adc_data_1, adc_data_2;
int val_TX[SAMPLES_TX];
const int LED_LCD = PA8;
int V_tic = 0;
int V_bat = 0;
int MENU_index = 1;
#define eeprom_adr 1
#define num_prof 4
#pragma pack(push, 1);
struct strMem
float amp_TX[num_prof];
int F_TX[num_prof];
int Threshold[num_prof];
int Comp_Phase[num_prof];
int need_phase[num_prof];
int Adjustment_Phase[num_prof];
int Prof;
} Mem;
const int OUT_TX = PB8;
dma_tube_config dma_cfg_TX, dma_cfg2;
timer_dev *dev_TX = PIN_MAP[OUT_TX].timer_device;//Timer4
uint8 cc_channel_TX = PIN_MAP[OUT_TX].timer_channel;//Channel3
void TX_conf()
Timer_4.pause();
Timer_3.pause();
Timer_3.setCount(0);
Timer_4.setCount(0);
set_sin_tab(Mem.Comp_Phase[Mem.Prof], Mem.amp_TX[Mem.Prof]);
timer_dma_set_base_addr(dev_TX, TIMER_DMA_BASE_CCR3);
timer_dma_set_burst_len(dev_TX, 1);
timer_dma_enable_req(dev_TX, cc_channel_TX);
// timer_set_reload(dev_TX, Mem.F_TX[Mem.Prof] );//++++++++++++++++++++++++++
timer_set_prescaler(dev_TX, 0);
Timer_4.setMasterModeTrGo(TIMER_CR2_MMS_COMPARE_OC3REF);
dma_init(DMA1);
dma_disable(DMA1, DMA_CH5);
dma_cfg_TX.tube_dst = &(dev_TX->regs.gen->DMAR);
dma_cfg_TX.tube_dst_size = DMA_SIZE_32BITS;
dma_cfg_TX.tube_src = val_TX;
dma_cfg_TX.tube_src_size = DMA_SIZE_32BITS;
dma_cfg_TX.tube_nr_xfers = SAMPLES_TX;
dma_cfg_TX.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
dma_cfg_TX.tube_req_src = DMA_REQ_SRC_TIM4_CH3;
dma_cfg_TX.target_data = 0;
dma_tube_cfg(DMA1, DMA_CH5, &dma_cfg_TX);
dma_enable(DMA1, DMA_CH5);
Timer_3.setPrescaleFactor(1);
Timer_3.setOverflow((SAMPLES_TX / 2) - 1);
timer_oc_set_mode(TIMER3, 3, TIMER_OC_MODE_TOGGLE, TIMER_OC_PE);
timer_oc_set_mode(TIMER3, 4, TIMER_OC_MODE_TOGGLE, TIMER_OC_PE);
Timer_3.setCompare(TIMER_CH3, 4);
Timer_3.setCompare(TIMER_CH4, 20);
Timer_3.setSlaveFlags( TIMER_SMCR_TS_ITR3 | TIMER_SMCR_SMS_EXTERNAL );
Timer_3.refresh();
Timer_4.refresh();
Timer_3.resume();
Timer_4.resume();
void set_sin_tab(int faze, float sin_amp)
float y;
float maxy = 0;
for (int i = 0; i < (SAMPLES_TX); i++) if ((y = F(dt * i)) > maxy) maxy = y;
// manually frequency changing = changing of f value = ok
//int f = 50;
//int f = 100;
//int f = 150;
//int f = 200;
//-------------------------------------------- using buttons = not working ----------------------------------
if (digitalRead(PB3) == LOW)
if(f>250) f= 250;
f++;
delay(100);
if (digitalRead(PB4) == LOW)
if(f<0) f= 0;
f--;
delay(100);
for (int i = 0; i < (SAMPLES_TX); i++) val_TX[i] = 1 + sin_amp * ((f - 1) / maxy) * F(dt * (i + faze)) ;
timer_set_reload(dev_TX, f );
//======================================================setup()==============================================================
//Serial.begin(9600);
pinMode(OUT_TX, PWM); //
pinMode(PB0, PWM); //Yy
pinMode(PB1, PWM); //Xy
pinMode(PA7, INPUT_PULLUP);
pinMode(PA6, INPUT_PULLUP);
pinMode(PB3, INPUT_PULLUP);
pinMode(PB4, INPUT_PULLUP);
pinMode(LED_LCD, OUTPUT);
lcd.begin(16, 2);
init_eeprom_mem();
TX_conf();
//=====================================================loop()============================================================
Serial.print("f = ");
Serial.println(f);
void init_eeprom_mem()
for (int i = 0; i < num_prof; i++)
Mem.amp_TX[i] = 1.0;
Mem.F_TX[i] = 160;
Mem.Prof = 0;
