Changing frequency of the generator
Hi
The program is from here.
http://ditrwsld13125710.blogspot.com/2013/10/very-simple-phase-detector-using-arduino.html
I just wonder it is difficult to change it to adjust the frequency of it by using 2 buttons ?
// Induction balance metal detector
// We run the CPU at 16MHz and the ADC clock at 1MHz. ADC resolution is reduced to 8 bits at this speed.
// Timer 1 is used to divide the system clock by about 256 to produce a 62.5kHz square wave.
// This is used to drive timer 0 and also to trigger ADC conversions.
// Timer 0 is used to divide the output of timer 1 by 8, giving a 7.8125kHz signal for driving the transmit coil.
// This gives us 16 ADC clock cycles for each ADC conversion (it actually takes 13.5 cycles), and we take 8 samples per cycle of the coil drive voltage.
// The ADC implements four phase-sensitive detectors at 45 degree intervals. Using 4 instead of just 2 allows us to cancel the third harmonic of the
// coil frequency.
// Timer 2 will be used to generate a tone for the earpiece or headset.
// Other division ratios for timer 1 are possible, from about 235 upwards.
// Wiring:
// Connect digital pin 4 (alias T0) to digital pin 9
// Connect digital pin 5 through resistor to primary coil and tuning capacitor
// Connect output from receive amplifier to analog pin 0. Output of receive amplifier should be biased to about half of the analog reference.
// When using USB power, change analog reference to the 3.3V pin, because there is too much noise on the +5V rail to get good sensitivity.
#define TIMER1_TOP (249) // can adjust this to fine-tune the frequency to get the coil tuned (see above)
#define USE_3V3_AREF (1) // set to 1 of running on an Arduino with USB power, 0 for an embedded atmega28p with no 3.3V supply available
// Digital pin definitions
// Digital pin 0 not used, however if we are using the serial port for debugging then it's serial input
const int debugTxPin = 1; // transmit pin reserved for debugging
const int encoderButtonPin = 2; // encoder button, also IN0 for waking up from sleep mode
const int earpiecePin = 3; // earpiece, aka OCR2B for tone generation
const int T0InputPin = 4;
const int coilDrivePin = 5;
const int LcdRsPin = 6;
const int LcdEnPin = 7;
const int LcdPowerPin = 8; // LCD power and backlight enable
const int T0OutputPin = 9;
const int lcdD0Pin = 10;
const int lcdD1Pin = 11; // pins 11-13 also used for ICSP
const int LcdD2Pin = 12;
const int LcdD3Pin = 13;
// Analog pin definitions
const int receiverInputPin = 0;
const int encoderAPin = A1;
const int encoderBpin = A2;
// Analog pins 3-5 not used
// Variables used only by the ISR
int16_t bins[4]; // bins used to accumulate ADC readings, one for each of the 4 phases
uint16_t numSamples = 0;
const uint16_t numSamplesToAverage = 1024;
// Variables used by the ISR and outside it
volatile int16_t averages[4]; // when we've accumulated enough readings in the bins, the ISR copies them to here and starts again
volatile uint32_t ticks = 0; // system tick counter for timekeeping
volatile bool sampleReady = false; // indicates that the averages array has been updated
// Variables used only outside the ISR
int16_t calib[4]; // values (set during calibration) that we subtract from the averages
volatile uint8_t lastctr;
volatile uint16_t misses = 0; // this counts how many times the ISR has been executed too late. Should remain at zero if everything is working properly.
const double halfRoot2 = sqrt(0.5);
const double quarterPi = 3.1415927/4.0;
const double radiansToDegrees = 180.0/3.1415927;
// The ADC sample and hold occurs 2 ADC clocks (= 32 system clocks) after the timer 1 overflow flag is set.
// This introduces a slight phase error, which we adjust for in the calculations.
const float phaseAdjust = (45.0 * 32.0)/(float)(TIMER1_TOP + 1);
float threshold = 10.0; // lower = greater sensitivity. 10 is just about usable with a well-balanced coil.
                                 // The user will be able to adjust this via a pot or rotary encoder.
  pinMode(encoderButtonPin, INPUT_PULLUP);
  digitalWrite(T0OutputPin, LOW);
  pinMode(T0OutputPin, OUTPUT); // pulse pin from timer 1 used to feed timer 0
  digitalWrite(coilDrivePin, LOW);
  pinMode(coilDrivePin, OUTPUT); // timer 0 output, square wave to drive transmit coil
  cli();
  // Stop timer 0 which was set up by the Arduino core
  TCCR0B = 0; // stop the timer
  TIMSK0 = 0; // disable interrupt
  TIFR0 = 0x07; // clear any pending interrupt
  // Set up ADC to trigger and read channel 0 on timer 1 overflow
#if USE_3V3_AREF
  ADMUX = (1 << ADLAR); // use AREF pin (connected to 3.3V) as voltage reference, read pin A0, left-adjust result
#else
  ADMUX = (1 << REFS0) | (1 << ADLAR); // use Avcc as voltage reference, read pin A0, left-adjust result
#endif
  ADCSRB = (1 << ADTS2) | (1 << ADTS1); // auto-trigger ADC on timer/counter 1 overflow
  ADCSRA = (1 << ADEN) | (1 << ADSC) | (1 << ADATE) | (1 << ADPS2); // enable adc, enable auto-trigger, prescaler = 16 (1MHz ADC clock)
  DIDR0 = 1;
  // Set up timer 1.
  // Prescaler = 1, phase correct PWM mode, TOP = ICR1A
  TCCR1A = (1 << COM1A1) | (1 << WGM11);
  TCCR1B = (1 << WGM12) | (1 << WGM13) | (1 << CS10); // CTC mode, prescaler = 1
  TCCR1C = 0;
  OCR1AH = (TIMER1_TOP/2 >> 8);
  OCR1AL = (TIMER1_TOP/2 & 0xFF);
  ICR1H = (TIMER1_TOP >> 8);
  ICR1L = (TIMER1_TOP & 0xFF);
  TCNT1H = 0;
  TCNT1L = 0;
  TIFR1 = 0x07; // clear any pending interrupt
  TIMSK1 = (1 << TOIE1);
  // Set up timer 0
  // Clock source = T0, fast PWM mode, TOP (OCR0A) = 7, PWM output on OC0B
  TCCR0A = (1 << COM0B1) | (1 << WGM01) | (1 << WGM00);
  TCCR0B = (1 << CS00) | (1 << CS01) | (1 << CS02) | (1 << WGM02);
  OCR0A = 7;
  OCR0B = 3;
  TCNT0 = 0;
  sei();
 // while (!sampleReady) {} // discard the first sample
  misses = 0;
  Serial.begin(19200);
// Timer 0 overflow interrupt. This serves 2 purposes:
// 1. It clears the timer 0 overflow flag. If we don't do this, the ADC will not see any more Timer 0 overflows and we will not get any more conversions.
// 2. It increments the tick counter, allowing is to do timekeeping. We get 62500 ticks/second.
// We now read the ADC in the timer interrupt routine instead of having a separate comversion complete interrupt.
ISR(TIMER1_OVF_vect)
  ++ticks;
  uint8_t ctr = TCNT0;
  int16_t val = (int16_t)(uint16_t)ADCH; // only need to read most significant 8 bits
  if (ctr != ((lastctr + 1) & 7))
    ++misses;
  lastctr = ctr;
  int16_t *p = &bins[ctr & 3];
  if (ctr < 4)
    *p += (val);
    if (*p > 15000) *p = 15000;
    *p -= val;
    if (*p < -15000) *p = -15000;
  if (ctr == 7)
    ++numSamples;
    if (numSamples == numSamplesToAverage)
      numSamples = 0;
      if (!sampleReady) // if previous sample has been consumed
        memcpy((void*)averages, bins, sizeof(averages));
        sampleReady = true;
      memset(bins, 0, sizeof(bins));
  //while (!sampleReady) {}
  uint32_t oldTicks = ticks;
  if (digitalRead(encoderButtonPin) == LOW)
    // Calibrate button pressed. We save the current phase detector outputs and subtract them from future results.
    // This lets us use the detector if the coil is slightly off-balance.
    // It would be better to everage several samples instead of taking just one.
    for (int i = 0; i < 4; ++i)
      calib[i] = averages[i];
    Serial.print("Calibrated: ");
      Serial.write(' ');
      Serial.print(calib[i]);
      averages[i] -= calib[i];
    const double f = 200.0;
    // Massage the results to eliminate sensitivity to the 3rd harmonic, and divide by 200
    double bin0 = (averages[0] + halfRoot2 * (averages[1] - averages[3]))/f;
    double bin1 = (averages[1] + halfRoot2 * (averages[0] + averages[2]))/f;
    double bin2 = (averages[2] + halfRoot2 * (averages[1] + averages[3]))/f;
    double bin3 = (averages[3] + halfRoot2 * (averages[2] - averages[0]))/f;
    sampleReady = false; // we've finished reading the averages, so the ISR is free to overwrite them again
    double amp1 = sqrt((bin0 * bin0) + (bin2 * bin2));
    double amp2 = sqrt((bin1 * bin1) + (bin3 * bin3));
    double ampAverage = (amp1 + amp2)/2.0;
    // The ADC sample/hold takes place 2 clocks after the timer overflow
    double phase1 = atan2(bin0, bin2) * radiansToDegrees + 45.0;
    double phase2 = atan2(bin1, bin3) * radiansToDegrees;
    if (phase1 > phase2)
      double temp = phase1;
      phase1 = phase2;
      phase2 = temp;
    double phaseAverage = ((phase1 + phase2)/2.0) - phaseAdjust;
    if (phase2 - phase1 > 180.0)
      if (phaseAverage < 0.0)
        phaseAverage += 180.0;
        phaseAverage -= 180.0;
    // For diagnostic purposes, print the individual bin counts and the 2 indepedently-calculated gains and phases
    Serial.print(misses);
    Serial.write(' ');
    if (bin0 >= 0.0) Serial.write(' ');
    Serial.print(bin0, 2);
    Serial.write(' ');
    if (bin1 >= 0.0) Serial.write(' ');
    Serial.print(bin1, 2);
    Serial.write(' ');
    if (bin2 >= 0.0) Serial.write(' ');
    Serial.print(bin2, 2);
    Serial.write(' ');
    if (bin3 >= 0.0) Serial.write(' ');
    Serial.print(bin3, 2);
    Serial.print(" ");
    Serial.print(amp1, 2);
    Serial.write(' ');
    Serial.print(amp2, 2);
    Serial.write(' ');
    if (phase1 >= 0.0) Serial.write(' ');
    Serial.print(phase1, 2);
    Serial.write(' ');
    if (phase2 >= 0.0) Serial.write(' ');
    Serial.print(phase2, 2);
    Serial.print(" ");
    // Print the final amplitude and phase, which we use to decide what (if anything) we have found)
    if (ampAverage >= 0.0) Serial.write(' ');
    Serial.print(ampAverage, 1);
    Serial.write(' ');
    if (phaseAverage >= 0.0) Serial.write(' ');
    Serial.print((int)phaseAverage);
    // Decide what we have found and tell the user
    if (ampAverage >= threshold)
      // When held in line with the centre of the coil:
      // - non-ferrous metals give a negative phase shift, e.g. -90deg for thick copper or aluminium, a copper olive, -30deg for thin alumimium.
      // Ferrous metals give zero phase shift or a small positive phase shift.
      // So we'll say that anything with a phase shift below -20deg is non-ferrous.
      if (phaseAverage < -20.0)
        Serial.print(" Non-ferrous");
        Serial.print(" Ferrous");
      float temp = ampAverage;
      while (temp > threshold)
        Serial.write('!');
        temp -= (threshold/2);
 while (ticks - oldTicks < 16000)
The frequency of the generator can be changed by changing the value of TIMER1_TOP.
How to modify the program so that the frequency could be changed with buttons?
I am thinking of something like that.
int k;
  pinMode(PB14, INPUT_PULLUP);
  pinMode(PB12, INPUT_PULLUP);
void frequency change ()
  if (digitalRead(PB12) == LOW)
    k++;
  if (digitalRead(PB14) == LOW)
    k--;
Replace TIMER1_TOP by a uint16_t variable indicating the frequency and simplify the 16 bit register access into
' ICR1 = k;'
Thanks for suggestion, I modified the program, but have no signal on pin D5.
int k;
#define TIMER1_TOP (220) // can adjust this to fine-tune the frequency to get the coil tuned (see above)
uint16_t frequency = k;
  pinMode(A1, INPUT_PULLUP);
  pinMode(A2, INPUT_PULLUP);
  cli();
#if USE_3V3_AREF
#else
#endif
  DIDR0 = 1;
  // Set up timer 1.
  TCCR1C = 0;
  //ICR1H = (TIMER1_TOP >> 8);
 // ICR1L = (TIMER1_TOP & 0xFF);
  ICR1 = k;
  TCNT1H = 0;
  TCNT1L = 0;
  // Set up timer 0
  OCR0A = 7;
  OCR0B = 3;
  TCNT0 = 0;
  sei();
  misses = 0;
  ++ticks;
    ++misses;
  lastctr = ctr;
  if (ctr < 4)
    *p += (val);
    *p -= val;
  if (ctr == 7)
    ++numSamples;
      numSamples = 0;
        sampleReady = true;
void frequencychange ()
  if (digitalRead(A1) == LOW)
    k++;
  if (digitalRead(A2) == LOW)
    k--;
      Serial.write(' ');
      phase1 = phase2;
      phase2 = temp;
    Serial.write(' ');
    Serial.write(' ');
    Serial.write(' ');
    Serial.write(' ');
    Serial.print(" ");
    Serial.write(' ');
    Serial.write(' ');
    Serial.write(' ');
    Serial.print(" ");
    Serial.write(' ');
        Serial.write('!');
This pin is related to timer 0, not 1.
You seem to have missed something. I mentioned k because you used it in your frequencyChange(). Update ICR1 whenever k changes.
Take a look at the State Change Detection example in the IDE (File->examples->02.digital->State change detection) and learn how to properly detect when a button gets pressed. Simply checking for it being LOW can result in many, many false positives. Your MCU is much faster than your finger pushing the button.
OR
Install the Buttion2 library and use that to handle all the details...
Here the constant value 'phaseAdjust' depends on TIMER1_TOP. You will have to change that from a constant to a variable and re-calculate the value every time TIMER1_TOP is changed.
const float phaseAdjust = (45.0 * 32.0) / (float)(TIMER1_TOP + 1);
Fortunately, it is used in only one place. That place is in loop() so it should not be long between changing 'phaseAdjust' and re-calculating 'phaseAverage'.
double phaseAverage = ((phase1 + phase2) / 2.0) - phaseAdjust;
You will also need to re-load OCR1A and ICR1 each time TIMER1_TOP is changed.
  OCR1A = TIMER1_TOP / 2;  // Set 50% duty cycle
  ICR1 = TIMER1_TOP;  // Set frequency
