I have a project I am doing and am wondering how easy it would be to change three buttons to control the timer setting to be a rotary encoder instead?
I have never worked with encoders, but saving space on the item would be hugely beneficial.
Any advice would be greatly appreciated
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4); // the I2C LCD address of your display might differ, in this case,
// DECLARATION:
// Power for LCD
int LCD_power = 8;
// beep/light
int signal_pin = 10;
int main_state = 0;
// Buttons
const int button_1 = 2;
boolean button_1_state = 0;
const int button_2 = 3;
boolean button_2_state = 0;
const int button_3 = 4;
boolean button_3_state = 0;
// Timer
int timer = 1;
int timer_sec;
float timer_fast;
float timer_faster;
int timer_sec_remainder;
int timer_min;
int SEQ = 300;
//Relay
const int RELAYPIN = 13;
// Bomb wires:
const int Red_wire = 12;
boolean R = 0;
const int Black_wire = 11;
boolean B = 0;
const int Green_wire = 7;
boolean G = 0;
const int Yellow_wire = 8;
boolean Y = 0;
int D_current[] = {R, B, G, Y};
// Disarm state:
int D_State = 0;
int D0[] = {0, 0, 0, 0};
int D1[] = {0, 0, 0, 0};
int D2[] = {0, 0, 0, 0};
int D3[] = {0, 0, 0, 0};
void activateRelay() {
digitalWrite(RELAYPIN, HIGH); // turn the LED on (HIGH is the voltage level)
void deactivateRelay() {
digitalWrite(RELAYPIN, LOW);
pinMode(LCD_power, OUTPUT);
digitalWrite(LCD_power, HIGH);
// Signal pin:
pinMode(signal_pin, OUTPUT);
// Buttons:
pinMode(button_1, INPUT);
pinMode(button_2, INPUT);
pinMode(button_3, INPUT);
lcd.init(); // initialize the lcd
Serial.begin(9600); // initialize debug serial
// Bomb wires:
pinMode(Red_wire, INPUT_PULLUP);
pinMode(Black_wire, INPUT_PULLUP);
pinMode(Green_wire, INPUT_PULLUP);
pinMode(Yellow_wire, INPUT_PULLUP);
// INTRO MESSAGE TO LCD:
digitalWrite(signal_pin, 1);
delay(50);
digitalWrite(signal_pin, 0);
delay(50);
delay(50);
delay(50);
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Set timer [min]:");
lcd.setCursor(0, 1);
lcd.print("timer = ");
lcd.print(timer);
// ... (existing code)
// STATE 0 - SET THE TIMER:
if (main_state == 0) {
button_1_state = digitalRead(button_1);
if (button_1_state == LOW) {
delay(100);
else if (button_1_state == HIGH) {
timer = timer + 1;
lcd.clear();
lcd.print(timer);
delay(150);
button_2_state = digitalRead(button_2);
if (button_2_state == LOW) {
delay(100);
else if (button_2_state == HIGH && timer > 1) {
timer = timer - 1;
lcd.clear();
lcd.print(timer);
delay(150);
button_3_state = digitalRead(button_3);
if (button_3_state == LOW) {
delay(1);
else if (button_3_state == HIGH) {
main_state = 1;
} // END STATE 0
// STATE 1 - SET SNOOSE AND DISARM:
else if (main_state == 1) {
lcd.clear();
lcd.print("Generating");
delay(200);
lcd.print("Generating.");
delay(200);
lcd.print("Generating..");
delay(200);
lcd.print("Generating...");
delay(200);
lcd.print("Done!");
// print a random number from 1 to 24, random(1, 25)
randomSeed(analogRead(0));
int SEQ = random(1, 25);
// SETTING THE SEQ:
if (SEQ == 1) {
lcd.clear();
lcd.print("KEY: R,B,G (01)");
// Set the Disarm steps {R,B,G,Y}:
//int D0[] = {0,0,0,0}; // Fully armed
//int D1[] = {1,0,0,0}; // *
D1[0] = 1;
//int D2[] = {1,1,0,0}; // **
D2[0] = 1;
D2[1] = 1;
//int D3[] = {1,1,1,0}; // Disarmed
D3[0] = 1;
D3[1] = 1;
D3[2] = 1;
else if (SEQ == 2) {
lcd.clear();
lcd.print("KEY: R,B,Y (02)");
D1[0] = 1;
D2[0] = 1;
D2[1] = 1;
//int D3[] = {1,1,0,1}; // Disarmed
D3[0] = 1;
D3[1] = 1;
D3[3] = 1;
else if (SEQ == 3) {
lcd.clear();
lcd.print("KEY: R,G,B (03)");
D1[0] = 1;
//int D2[] = {1,0,1,0}; // **
D2[0] = 1;
D2[2] = 1;
D3[0] = 1;
D3[1] = 1;
D3[2] = 1;
else if (SEQ == 4) {
lcd.clear();
lcd.print("KEY: R,G,Y");
D1[0] = 1;
D2[0] = 1;
D2[2] = 1;
//int D3[] = {1,0,1,1}; // Disarmed
D3[0] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 5) {
lcd.clear();
lcd.print("KEY: R,Y,B");
D1[0] = 1;
//int D2[] = {1,0,0,1}; // **
D2[0] = 1;
D2[3] = 1;
D3[0] = 1;
D3[1] = 1;
D3[3] = 1;
else if (SEQ == 6) {
lcd.clear();
lcd.print("KEY: R,Y,G");
D1[0] = 1;
D2[0] = 1;
D2[3] = 1;
D3[0] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 7) {
lcd.clear();
lcd.print("KEY: B,R,G");
//int D1[] = {0,1,0,0}; // *
D1[1] = 1;
D2[0] = 1;
D2[1] = 1;
D3[0] = 1;
D3[1] = 1;
D3[2] = 1;
else if (SEQ == 8) {
lcd.clear();
lcd.print("KEY: B,R,Y");
D1[1] = 1;
D2[0] = 1;
D2[1] = 1;
D3[0] = 1;
D3[1] = 1;
D3[3] = 1;
else if (SEQ == 9) {
lcd.clear();
lcd.print("KEY: B,G,R");
D1[1] = 1;
//int D2[] = {0,1,1,0}; // **
D2[1] = 1;
D2[2] = 1;
D3[0] = 1;
D3[1] = 1;
D3[2] = 1;
else if (SEQ == 10) {
lcd.clear();
lcd.print("KEY: B,G,Y");
D1[1] = 1;
D2[1] = 1;
D2[2] = 1;
//int D3[] = {0,1,1,1}; // Disarmed
D3[1] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 11) {
lcd.clear();
lcd.print("KEY: B,Y,R");
D1[1] = 1;
//int D2[] = {0,1,0,1}; // **
D2[1] = 1;
D2[3] = 1;
D3[0] = 1;
D3[1] = 1;
D3[3] = 1;
else if (SEQ == 12) {
lcd.clear();
lcd.print("KEY: B,Y,G");
D1[1] = 1;
D2[1] = 1;
D2[3] = 1;
D3[1] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 13) {
lcd.clear();
lcd.print("KEY: G,R,B");
//int D1[] = {0,0,1,0}; // *
D1[2] = 1;
D2[0] = 1;
D2[2] = 1;
D3[0] = 1;
D3[1] = 1;
D3[2] = 1;
else if (SEQ == 14) {
lcd.clear();
lcd.print("KEY: G,R,Y");
D1[2] = 1;
D2[0] = 1;
D2[2] = 1;
D3[0] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 15) {
lcd.clear();
lcd.print("KEY: G,B,R");
D1[2] = 1;
D2[1] = 1;
D2[2] = 1;
D3[0] = 1;
D3[1] = 1;
D3[2] = 1;
else if (SEQ == 16) {
lcd.clear();
lcd.print("KEY: G,B,Y");
D1[2] = 1;
D2[1] = 1;
D2[2] = 1;
D3[1] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 17) {
lcd.clear();
lcd.print("KEY: G,Y,R");
D1[2] = 1;
//int D2[] = {0,0,1,1}; // **
D2[2] = 1;
D2[3] = 1;
D3[0] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 18) {
lcd.clear();
lcd.print("KEY: G,Y,B");
D1[2] = 1;
D2[2] = 1;
D2[3] = 1;
D3[1] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 19) {
lcd.clear();
lcd.print("KEY: Y,R,B");
//int D1[] = {0,0,0,1}; // *
D1[3] = 1;
D2[0] = 1;
D2[3] = 1;
D3[0] = 1;
D3[1] = 1;
D3[3] = 1;
else if (SEQ == 20) {
lcd.clear();
lcd.print("KEY: Y,R,G");
D1[3] = 1;
D2[0] = 1;
D2[3] = 1;
D3[0] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 21) {
lcd.clear();
lcd.print("KEY: Y,B,R");
D1[3] = 1;
D2[1] = 1;
D2[3] = 1;
D3[0] = 1;
D3[1] = 1;
D3[3] = 1;
else if (SEQ == 22) {
lcd.clear();
lcd.print("KEY: Y,B,G");
D1[3] = 1;
D2[1] = 1;
D2[3] = 1;
D3[1] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 23) {
lcd.clear();
lcd.print("KEY: Y,G,R");
D1[3] = 1;
D2[2] = 1;
D2[3] = 1;
D3[0] = 1;
D3[2] = 1;
D3[3] = 1;
else if (SEQ == 24) {
lcd.clear();
lcd.print("KEY: Y,G,B");
D1[3] = 1;
D2[2] = 1;
D2[3] = 1;
D3[1] = 1;
D3[2] = 1;
D3[3] = 1;
// Move to next state:
main_state = 2;
} // END STATE 1
// STATE 2 -:
else if (main_state == 2) {
// CONFIRM USER WROTE DOWN THE KEY:
lcd.print("Press B2 to ARM");
delay(100);
lcd.clear();
lcd.print("ARMED:");
lcd.setCursor(7, 0);
//lcd.print(timer_sec);
timer_min = int(timer_sec / 60);
timer_sec_remainder = timer_sec % 60;
if (timer_min < 10) {
lcd.print("0");
else {
Serial.print(" ");
lcd.print(timer_min);
if (timer_sec_remainder < 10) {
lcd.print(":0");
else {
lcd.print(":");
lcd.print(timer_sec_remainder);
timer_sec = timer * 60;
timer_fast = timer_sec / 6;
timer_faster = timer_fast / 3;
main_state = 3;
// END STATE 2
// STATE 3 -:
// - run timer
else if (main_state == 3) {
lcd.clear();
lcd.print("0");
else {
Serial.print(" ");
lcd.print(":0");
else {
lcd.print(":");
if (D_State == 0) {
lcd.print("***");
else if (D_State == 1) {
lcd.print("**");
else if (D_State == 2) {
lcd.print("*");
if (timer_sec <= 1) {
main_state = 4;
else if (timer_sec < timer_faster) {
delay(50);
timer_sec = timer_sec - 1;
delay(200);
delay(50);
delay(200);
delay(50);
delay(200);
delay(50);
delay(200);
else if (timer_sec < timer_fast) {
delay(50);
delay(400);
delay(50);
delay(400);
else if (timer_sec > 1) {
delay(50);
delay(950);
//- check D_current
check_D_current();
if (D_State == 0) {
if (
D_current[0] == D0[0] and
D_current[1] == D0[1] and
D_current[2] == D0[2] and
D_current[3] == D0[3]
Serial.println(" ");
else {
if (
D_current[0] == D1[0] and
D_current[1] == D1[1] and
D_current[2] == D1[2] and
D_current[3] == D1[3]
D_State = 1;
delay(50);
delay(50);
delay(50);
delay(50);
//----- if D_current != D1 -> BOOM
else {
main_state = 4;
} // end D_State == 0
if (D_State == 1) {
if (
else {
Serial.println(D2[0]);
Serial.println(D2[1]);
Serial.println(D2[2]);
Serial.println(D2[3]);
if (
D_current[0] == D2[0] and
D_current[1] == D2[1] and
D_current[2] == D2[2] and
D_current[3] == D2[3]
D_State = 2;
delay(50);
delay(50);
delay(50);
delay(50);
else {
main_state = 4;
} // end D_State == 1
if (D_State == 2) {
//--- if D_current == D0 : pass
if (
//--- else if D_current != D0:
else {
//----- else if D_current == D1 -> D_state = 1
if (
D_current[0] == D3[0] and
D_current[1] == D3[1] and
D_current[2] == D3[2] and
D_current[3] == D3[3]
D_State = 3;
delay(50);
delay(50);
delay(50);
delay(50);
else {
main_state = 4;
} // end D_State == 2
if (D_State == 3) {
lcd.clear();
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
lcd.print(" BOMB DEFUSED");
delay(1000000);
} // end D_State == 3
} // END STATE 3
// STATE 4 - BOOM, TERRORISTS WIN:
else if (main_state == 4) {
lcd.clear();
lcd.print(" BOMB EXPLODED");
activateRelay();
delay(5000);
deactivateRelay();
delay(100);
delay(10000);
} // END STATE 4
} // END LOOP
// Check current bomb wires config:
void check_D_current() {
R = digitalRead(Red_wire);
B = digitalRead(Black_wire);
G = digitalRead(Green_wire);
Y = digitalRead(Yellow_wire);
// Print for debug:
Serial.println("D_current:");
D_current[0] = R;
D_current[1] = B;
D_current[2] = G;
D_current[3] = Y;
Serial.println(D_current[0]);
Serial.println(D_current[1]);
Serial.println(D_current[2]);
Serial.println(D_current[3]);
