changing from serial to bluetooth using BT
hey all;
i ve created a code that connects web-server to arduino uno. then i ve tried to upgrade it using BT shield but things got messy during the process.
my problem is that the receiver started so well but am still having a problem with the transmitter. it turns on and keeps on since i connect the power without transmitting anything.
1 other thing the when i disconnect the the arduino then reconnect it again. sometimes the code doesn't work. or acts weird? is that normal ?
 * IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
 * An IR LED must be connected to Arduino PWM pin 3.
 * Version 0.1 July, 2009
 * Copyright 2009 Ken Shirriff
 * http://arcfn.com
//16455911
#include <IRremote.h>
#include <SoftwareSerial.h> //Software Serial Port
IRsend irsend;
#define RxD 2
#define TxD 3
SoftwareSerial Bt(RxD,TxD);
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
String readString;
long unsigned value;
  pinMode(RxD, INPUT);
  pinMode(TxD, OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
  bluetoothInitiate();
void bluetoothInitiate(){
 // this part is copied from the Seeeduino example*
 Bt.begin(38400); // this sets the the module to run at the default bound rate
 Bt.print("\r\n+STWMOD = 0\r\n");        //set the bluetooth work in slave mode
 Bt.print("\r\n+STNA=Spartan\r\n"); //set the bluetooth name as "SeeedBTSlave"
 Bt.print("\r\n+STOAUT=1\r\n");          // Permit Paired device to connect me
 Bt.print("\r\n+STAUTO=0\r\n");          // Auto-connection should be forbidden here
 delay(50);                            // This delay is required.
 Bt.print("\r\n+INQ=1\r\n");             //make the slave bluetooth inquirable
 Bt.flush();
 Bt.println("Bluetooth connection established correctly!"); // if connection is successful then print to the master device
String Buffer;
  //delay(50);
  while(Bt.available() && Serial.read() == '0') {//Serial
    //Serial.print("Transmitting");
    while (Serial.available() == 0) {//Serial
    delay(50);
    while (Serial.available() > 0 ) {//Serial
    Buffer = (String)Bt.read();//Serial
    //value = Buffer.toInt();
    Serial.println(value);
    Bt.println(value);  //Serial.println
    //for (int i = 0; i < 3; i++) {
          //  irsend.sendNEC(value,32);
           // delay(40);
    Buffer = "";
         if (irrecv.decode(&results)) {
           Bt.println("Receiving");//Serial
           Serial.println(results.value);
           Bt.println(results.value);
           irrecv.resume();
Why are you using while loops and why do you have while loops that do absolutely nothing? What updates "value" now that you commented out the line that is supposed to update it? And don't use Strings, there is no need to be using them. If you need to change the incoming chars to an int then use this:
value = value * 10 + (Buffer - '0' );
When you're done with it, set value back to zero.
HazardsMind:
can u please show me what u meant in code? cause am kinda got lost and i think amn't getting u right
No while loops, and no Strings.
char Buffer;
  if(Serial.available() > 0)
     char SerialChar = Serial.read() ;
  if(Bt.available() && SerialChar== '0') //Serial
    Buffer = Bt.read();//Serial
    value = value *10 +(Buffer - '0');
    value = 0;
    irrecv.resume();
EDIT:
I added this because I missed it before.
** char SerialChar = Serial.read() ;**
HazardsMind:
char Buffer;
  //delay(50);
  if(Bt.available() && Serial.read() == '0') //Serial
    value = 0;
    irrecv.resume();
but u didn't declare the type of value? also will the serial.read take what is written from the serial monitor by BT? does the BT shield send the whole string at one or character by character?
Thanks for ur support
Look at my edit on my previous post
I know that, I left a lot of stuff out. You can put them in, I just wanted to show you what your code will look like without pointless while loops.
character by character.
HazardsMind:
thank u :slight_smile:
HazardsMind:
also i really need to know doesserial.read take what is written from the serial monitor by BT?
In your sketch Serial.read get chars from the Serial monitor, and Bt.read gets chars from your bluetooth.
HazardsMind:
so if i write
 bt.println();
serial.read();
will the serial.read take what the bt.print have wrote, please confirm
No. You should read up on the differences between Serial and Software Serial, and how they work. You are not going to see anything from the BT module unless you say Serial.println( Bt.read() );
HazardsMind:
Dear Sir. what am trying to do is transmitting the code through IR LED which is being send by B.T shield using SSCOM3.2
while(Bt.available() && Bt.read() == 0 ) {
    Bt.print("Transmitting");
   while (Bt.available() == 0) {
    delay(50);
    while (Bt.available() > 0 ) {
    readString += (char)Bt.read();
    value = readString.toInt();
            delay(40);
    readString = "";
My condition is simple. if the first character the shield receive is being 0 then enter the transmitting mode, go in a while loop till u finish reading the whole string "bt.available> 0" save it to variable "value" then transmit "value". if the 1st character isn't 0 then go to the receiving mode and start detecting what is being send. ( the receiving works perfectly "
my problem now is that SCOM3.2 doesn't allow me to send and the IDE 1.0.5 lags when trying to connect to the Bluetooth port. so am n't sure if it's transmitting problem issue or SSCOM3.2?
any help is appreciated, also if u would like to modify it please do
It's most likely is the SSCOM3.2.
When you try to transmit, you should see on your screen a message " bluetooth connection was established", do you ever see this? From what I saw, a lot of people were having issues with that shield. Some were saying it wasn't compatible with their Arduino, another said he solved it by reversing the TX and RX in the code and for the rest, it still did not work.
I'm sure you played with the example codes to see if your IR is working, right? Start by getting one piece to work, at a time then combine them. Make sure everything works indepently first then begin to add more.
