Changing HC05 AT commands
Hey all trying to turn my HC 05 from slave to master mode ive gotten into AT command mode as indicated by the slow blinking light
but it wont react in anyway to any command I send it over the serial monitor?
Gee, I wonder what code he is using? Something secret, I suppose, and much the same can be said for the wiring…
your don’t need any coding you set up the wiring as follows
https://www.instructables.com/file/F6ANCCUIQ41XMWX/
Then you bring the Ent Pin high and the module should go into AT command mode as shown by a slow blinking light
at that point you can open the serial monitor
However in my case it wont take the commands
