Changing I2C Ports on sparkfun nrf52840 mini board
For my new project I want to read the data from a bno055. For this I would love to use the adafruit sensor library. But I can't get it to run. I think my problem is that in the Wire files the I2C pins are set to something else than what I use.
I wanted to ask: how can I see which pins are set?
How would I change it to an other pin?
Thanks so much for your help.
Usually the pins 22/23 are used for I2C. You can change the pin settings by calling the method setPins(pinSDA, pinSCL) on the Wire object.
Hello,
i am encountering the same problem that satge have. i'am not able to connect with any I2C device.
The board sparkfun nrf52840 have the QWIIK connector, that i already tried to connect in my module, but didn't get any signal. Also, i tried the 22/23 pins, but also nothing. The method setPins isn't avaliable in my library, wich one are you using?
The module that i'am trying to connect is the simple MPU6050.
Thanks,
Best o regards.
Alexandre
Using the honnet nRF5 core.
