Changing led sequence with buttons
I was wondering if any anyone could help me, I have an array of LEDs that I would like to animate however I want to have 4 buttons which change the led’s animation. I was unsure of the best way to do this. I was thinking of having the buttons change a variable when pressed and then a Switch case check what the variable is.
You may be able to set the output as a byte and when a button is pressed it changes the byte being outputed.
Button1: byte:01010101 Button2: byte:00110011 Button3: byte:11001100 Button4: byte:10101010
Im not sure if the I/O pins can be turned on like that, or not, but it is worth a try as opposed to: digitalWrite(led1,HIGH); digitalWrite(led2,LOW); digitalWrite(led3,HIGH); digitalWrite(led4,LOW); and so on.
try sending out a byte and see if it works.
Actually im curious as to see if: digitalWrite(0AAA,HIGH); //0AAA = 0000|1010|1010|1010 as a 13 pin byte I doubt it will work but, it would nice if it did.
Post your existing code. If you haven't already look at blink without delay and button debouncing.
Mark
Wait I for got something, it would be 0x0AAA not just 0AAA.
