Changing mode using switch button
hi I'm making a combination of useless box and shy box, so there's two modes and to change between the two modes, I want to use a switch button. How to write the code?
In setup, declare a pin as pinMode(x, INPUT_PULLUP);
In loop, check the pin and respond accordingly
if(digitalRead(x)
mode(1);
mode2();
where can I put the code?
Hello
You can use the Arduino IDE for example.
Preferably, inside the Arduino :stuck_out_tongue:
If there are only going to be two modes, and the code is fairly basic then this kind of setup could work well:
(Note - as in the Wokwi, only two of the switch poles are used, an outer pole to ground and the middle pole to a digital pin).
#define SWITCH_PIN 13
  pinMode(SWITCH_PIN, INPUT_PULLUP);
  digitalRead(SWITCH_PIN) ? doModeOneStuff() : doModeTwoStuff();
void doModeOneStuff() {
  Serial.println("Doing Mode One Stuff");
void doModeTwoStuff() {
  Serial.println("Doing Mode Two Stuff");
Of course you might need to swap the order around inside the digitalRead(SWITCH_PIN) ? doModeOneStuff() : doModeTwoStuff(); line. And all of the Serial lines can be removed when you are finished debugging with them.
