Changing MPU6050 range
Using MPU6050 Adafruit library, I tried to set accelerometer range to +-4g, and gyroscope range to +-500 deg/s. However, when I start printing the data, I still get accelerations going well and over +4g or -4g. Even going up to 16g. Is there something wrong with my code? Or did I not get the concept properly, help would be appreciated thank you so much.
The void setup
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  mpu.begin();
  mpu.setAccelerometerRange(MPU6050_RANGE_4_G);
  mpu.setGyroRange(MPU6050_RANGE_1000_DEG);
  mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
To print the data
void printData(int i) {
  sensors_event_t a, g, temp;
  mpu.getEvent(&a, &g, &temp);
  Serial.print(i);
  Serial.print(',');
  Serial.print(a.acceleration.x, 5);
  Serial.print(',');
  Serial.print(a.acceleration.y, 5);
  Serial.print(',');
  Serial.print(a.acceleration.z, 5);
  Serial.print(',');
  Serial.print(g.gyro.x, 5);
  Serial.print(',');
  Serial.print(g.gyro.y, 5);
  Serial.print(',');
  Serial.println(g.gyro.z, 5);
Here is what the data looks like on my serial monitor, with the first column printing the line count.
What is G’s value? ( Gravitational acceleration)
Hence How much is 4G?
