Changing parameters in function
Not sure of the syntax for changing parameters provided to a function, this is what I have, can you help with the correct syntax please?
//                       Add to running average
void AddToRunningAverage(long *CurrentAverage,long *CountOfItems,int NewValue) {
     *CountOfItems++ ;
     *CurrentAverage = (*CurrentAverage * *CountOfItems + NewValue) / (*CountOfItems + 1) ;
Called with :-
 AddToRunningAverage(&TempRunningAverage,&TempAverageCount,Temp) ;
Thanks!
Syntax looks fine to me.
Still cant figure it, Light is averaging but temperature isnt, I get 1 for the average, 70.8 - 71.2 are the max an min, no clue why!
//                             LIBRARY INCLUDES
#include "LedControl.h"
//                          VARIABLE INITIALIZATION
unsigned long LightRunningAverage = 0;
unsigned long LightAverageCount   = 0 ;
unsigned long TempRunningAverage = 0 ;
unsigned long TempAverageCount   = 0 ;
int MaxLight = 0 ;
int MinLight = 9999 ;
int MaxTemp = 0 ;
int MinTemp = 9999 ;
int TempSensor = 3 ;
int LightSensor =0 ;
LedControl lc=LedControl(9,10,11,1);
//                             SETUP FUNCTION
     Serial.begin(9600) ;
     analogReference(INTERNAL) ;
     lc.shutdown(0,false);
     lc.setIntensity(0,1);
     lc.clearDisplay(0);
//                             LOOP FUNCTION
     ProcessLight() ;
     ProcessTemp() ;
//                       Process Light Readings
void ProcessLight() {
     int Light = readLight(LightSensor) ;
     AddToRunningAverage(&LightRunningAverage,&LightAverageCount,Light) ;
     if (Light > MaxLight) {
          MaxLight = Light ;
     if (Light < MinLight) {
          MinLight = Light ;
     printMin(MinLight) ;
     printMax(MaxLight) ;
     delay(1000) ;
     printAve(LightRunningAverage) ;
     delay(1000) ;
//                       Process Temperature Readings
void ProcessTemp() {
     int Temp = readTempF() ;
     if (Temp > MaxTemp) {
          MaxTemp = Temp ;
     if (Temp < MinTemp) {
          MinTemp = Temp ;
     printMax(MaxTemp) ;
     printMin(MinTemp) ;
     delay(1000) ;
     printAve(TempRunningAverage) ;
     delay(1000) ;
void AddToRunningAverage(unsigned long *CurrentAverage,unsigned long *CountOfItems,int NewValue) {
     *CountOfItems++ ;
any ideas, I'm new to C syntax so perhaps there is something I am missing!
TIA
Would you be able to post readTempF()?
Have you tried printing out the value that this returns?
     *CountOfItems++;
switch the order of your operations like the above, otherwise your are multiplying the old average with the new count of items.
You would get better precision by storing the sum rather than the average, (i.e. dividing with count only when you are going to print the result)
How can you get 70.8 as min temperature when you're storing it in an int? Does readTempF return deci-Fahrenheits?
LOL, thanks drhex, I guess I shouldn't write code when I wake up at 2am!
That seems to have solved the problem!! Full code is below
// Hardware :
// 2x 4 digit LED display connected to MAX7219 on pins 9,10,11
// LM35 precision temp sensor connected to Analog 3
// LDR connected to + , 26.8K resistance to ground connected in middle to Analog 0 ;
//                             LIBRARY INCLUDES
int delayFactor = 1000 ;
int MaxLight = 0 ;
int MaxTemp = 0 ;
//                             SETUP FUNCTION
     lc.clearDisplay(0);
//                             LOOP FUNCTION
     ProcessLight() ;
     ProcessTemp() ;
     displayReadings() ;
//                       Display Heat
void DisplayHeat() {
     lc.setChar(0,2,'h',false) ;
     lc.setChar(0,3,'e',false) ;
     lc.setChar(0,4,'a',false) ;
     lc.setRow(0,5,B00001111) ;
//                       Display Light
void DisplayLight() {
     lc.setChar(0,2,'l',false) ;
     lc.setChar(0,3,'1',false) ;
     lc.setChar(0,4,'9',false) ;
     lc.setChar(0,5,'h',false) ;
     lc.setRow(0,6,B00001111) ;
//                       Send Readings To Serial Port
void SendToSerial() {
     Serial.print("T :") ;
     Serial.print("Min ") ;
     Serial.print(MinTemp) ;
     Serial.print(" Max ") ;
     Serial.print(MaxTemp) ;
     Serial.print(" Ave ") ;
     Serial.print(TempRunningAverage) ;
     Serial.print(" L :") ;
     Serial.print(MinLight) ;
     Serial.print(MaxLight) ;
     Serial.println(LightRunningAverage) ;
//                       Output Stats
void OutputStats(int Min,int Max,unsigned long Average) {
     delay(delayFactor) ;
     printMax(Max) ;
     printMin(Min) ;
     delay(3*delayFactor) ;
     printAve(Average) ;
//                       Display Readings
void displayReadings() {
     SendToSerial() ;
     DisplayHeat() ;
     OutputStats(MinTemp,MaxTemp,TempRunningAverage) ;
     DisplayLight() ;
     OutputStats(MinLight,MaxLight,LightRunningAverage) ;
          MaxLight = Light ;
          MinLight = Light ;
          MaxTemp = Temp ;
          MinTemp = Temp ;
     *CountOfItems++ ;
//                  PLACE LONG ON left 4 Digits, fixed decimal xxx.x
void printLED(unsigned long Number,int StartDigit,int DPDigit) {
     unsigned long TempNum = Number % 100000000 ;
     int CurrentDigit = StartDigit ;
     while (TempNum > 0) {
          if (CurrentDigit == DPDigit) {
               lc.setDigit(0,CurrentDigit,TempNum % 10,true) ;
          else {
               lc.setDigit(0,CurrentDigit,TempNum % 10,false) ;
          TempNum = TempNum / 10 ;
          CurrentDigit-- ;
     for (CurrentDigit ; CurrentDigit >= 0 ; CurrentDigit--) {
          lc.setRow(0,CurrentDigit,0) ;
//                       PLACE LONG ON LED DISPLAY VIA 7219
void printLEDLong(unsigned long Number) {
     printLED(Number,7,8) ;
void printAve(unsigned long Number) {
     printLEDLong(0) ;
     printLED(Number,5,4) ;
void printMin(unsigned long Number) {
     printLED(Number,3,2) ;
//                  PLACE LONG ON Right 4 Digits, fixed decimal xxx.x
void printMax(unsigned long Number) {
     printLED(Number,7,6) ;
//                 Read value from light sensor re-scale 0-1000
int readLight(int analogPort) {
     SetDefaultReference() ;
     return(readAnalog(LightSensor,20)*1000/1023 ) ;
//                   Read Tempreature from LM35 in F
int readTempF() {
     return(readTempC() * 9 / 5 + 320);
//                   Read Tempreature from LM35 in C
int readTempC() {
     SetInternalReference();
     return(((100*1.1*readAnalog(TempSensor,20))/1024)*10);
//              Averaging Read From Port
long readAnalog(int Port, int Samples) {
     long Accumulator = 0 ;
     for (int i = 0; i < Samples ; i++) {
          Accumulator = Accumulator + analogRead(Port);
     return(Accumulator / Samples) ;
//              Set internal reference discard next results
void SetInternalReference() {
     for (int j =0 ; j<10 ; j++) {
          analogRead(0) ;
          delay(40) ;
//               Set DEFAULT reference discard next results
void SetDefaultReference() {
     analogReference(DEFAULT) ;
          analogRead(0) ;
          delay(40) ;
