Can anyone help out please i'm working n a project to accept a rs232 data String (not yet got to this point)
and output it through another RS232 connection via myString.printLn(StringValue) ; this outputs correct to hyper terminal
(i'm using the class String)
but i can only get output if i set bps to 9600 , data bits 7 , parity NONE , stop bits 1
but i need it to output and accept (when i get here from RS232) at :
bps to 9600 , data bits 7 , parity EVEN , stop bits 1
Can anyone point me in the direction please on how i would change the parity bit for input and the output.
Take a look at the implementation of the NewSoftSerial class how it implemented the 8 bits communication and you can derive a 7 bit version with optional stopbits etc.
see - NewSoftSerial | Arduiniana -
i have looked and looked for the information but I'm unable to find it , can you give me an other pointer to the documentation please .I would like to use the Serial devices on the mega 2560 i will be using Serial2 and Serial3
I to found this and tried to implement it on a mega 2560 , but it will not work no matter what combination i try i even done away with the libary and implamented some of the code direct in my project , but no changes to the parity was achived.
