Changing serial ports in .h files
Hello
I have a Nextion screen that needs to use the serial ports on my Pro Mini.
I currently have some DMX code using the serial port, so I need to move one of them.
I seem to remember that the Nextion screen does not like using software serial ports, so it makes sense to move the DMX if possible… here is where I fail.
I don’t exactly understand what I need to change in the DMXserial.h file to allow me to specify the Software serial port pins.
On that note… I assume I can assign any pins on the Pro Mini to be software serial?
Any guidance would be appreciated
DMXSerial.h (6.4 KB)
I don't exactly understand what I need to change in the DMXserial.h file to allow me to specify the Software serial port pins.
I suggest that you start with reading line 1 of the file you attached.
The DMX heavily relies on the HardwareSerial (because DMX relies on timing) so I doubt that's the smart move.
Nexion just uses some simple commands so I don't see why that would not work.
Well to be fair, most of these serial files declare they are using the serial port. Doesn't mean they can't be moved (... whether they work after that is another issue).
The (very good) Nextion screen tutorial I was watching on Youtube stated that after experimenting, he could not get reliable results using software serial.
OK. So both need the default serial port.
Looks like I either bin the Pro Mini, or jump over to a different platform (don't have space for a Mega)
Thought of a Teensy as it has more serial ports, but the code/library won't compile at all on that.
There are Mega clones that are the same size as the Uno.
Like I said, the Nexion doesn't really do much special with Serial so I would start by trying to use SoftSerial for that before jumping to conclusions. There are a lot of people writing tutorials full of crap. ::slight_smile:
Arduino_Steve:
I seem to remember that the Nextion screen does not like using software serial ports, so it makes sense to move the DMX if possible.... here is where I fail.
Assuming your Nextion display is set to the default 9600 baud then have you tried it with software serial?
You will have zero chance of getting DMX to run on software serial as it needs to be at 250000 baud and software serial can maybe manage 38400 baud.
I have not managed to get the Nextion to use Software serial.
Read a few links regarding getting that to work…
Changed the Nextion config file (NexConfig.h) - attached:
//#define nexSerial Serial2
#include <SoftwareSerial.h>
extern SoftwareSerial HMISerial;
#define nexSerial HMISerial
Then declare in my code:
#include “Nextion.h”
SoftwareSerial HMISerial(13,12);
But it complies with an error and I can’t shift it…
HardwareSerial0.cpp.o (symbol from plugin): In function Serial':* *(.text+0x0): multiple definition of __vector_18’
C:\Users\STEVEC~1\AppData\Local\Temp\arduino_build_118855\libraries\DMXSerial-master\DMXSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
HardwareSerial0.cpp.o (symbol from plugin): In function Serial':* *(.text+0x0): multiple definition of __vector_19’
collect2.exe: error: ld returned 1 exit status
Its basically clashing with the DMX config file and I cannot see why
NexConfig.h (1.37 KB)
Disable dbSerial as told in the readme :wink:
I have disabled dbSerial. Same issue.
Google turns up that this 'Vector 18' issue is a problem that doesn't appear to have been solved
Arduino_Steve:
The vector 18 issue is happening because two libraries are trying to use the same interrupt handler. HardwareSerial uses the ones at __vector_18 and __vector_19. So does some other library you are using.
The solution is quite simple. Don't do that.
PaulS:
Useful. I know that I 'don't want to do that'.... but HOW do I not do that.
There is nothing I can see with my hobby level eye in the config files that will change anything.
I can only assume it is a deeper issue.
I think its time to abandon the Pro Mini for this project and move to something else.
What that will be, I am not sure
You have some code that you haven't shared. There are at least three libraries involved, but we've only seen one file from one library. Can you see why we can't help you?
Yeah, HardwareSerial Serial uses the same vectors but after changing the Nextion config I don't see why Serial should be called.... Aka, why and where it's done after removing the references to serial from Nextion-library.
The conflict is between the DMX and the Nextion libraries. Comment either one out, and the code compiles.
Only other libraries in use are wire.h and EEprom.
I know you can't use debug serial anywhere else otherwise it causes issues (many people with that issue).
Thank you for the suggestions. I will investigate later on. Tired of looking at it currently
Did you comment out #define DEBUG_SERIAL_ENABLE to disable debug mode.
Can you maybe try a different Nextion library.
Yes. Tried different library and Debug is commented out
