Hi, I have come to wonder whether it is possible to change a specific character from a byte
My byte is part of a byte array:
byte f00[8] = {
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000
I have then picked no. 0 in this array:
f00[0]
And then I want to change the 5'th character in this first byte in the array.
I think it would be pretty easy to do if I could convert this byte to a String, and then use things like
split to change the specific char, and then change it back to a byte (which it btw has to be, I can't change that).
But I can't seem to figure out how to do this.
Your array holds 8 bytes
Each byte could hold a single character so you can't
You could change the 5th bit in the first byte of the array. Do you understand the difference between a bit and a byte ?
If it means to change the 4th bit , use bitwise XOR.
e.g.
f00[0] ^= 1 << 4;
This swaps the bit.
If it is 0, it is set to 1.
If it is 1, it is set to 0.
Although 4 is specified, because the rightmost bit is the 0th bit.
So it is counted as 4 3 2 1 0 instead of 5 4 3 2 1 .
Or use the bitRead() and bitWrite() functions if you are not comfortable with bit masking and shifting
byte bitValue = bitRead(f00[0], 4);
bitWrite(f00[0], 4, !bitValue);
system
Closed
October 27, 2021, 7:49am
5
