Hi, I have tested this as a loopback with microphone input and output filters.
It is acceptable quality for my project.
Over the last year I was hoping a solution would be found to smoothly varying the playback speed of 1500 values stored in the array dd[1511].
At the moment the sketch uses the pre-scaler on Timer2 to set the output sample frequency.
So only jumps in speed are possible by changing pre-scaler values.
That is unavoidable because of the use of PWM output.
There may be glitches/artifacts if a pot input was used to change the playback sample frequency on the fly, but since I haven't a solution to that yet, I don't know how intrusive that would be.
I am keeping the hardware as simple as possible, not wanting to get into a DAC solution, because this is a modular unit of at least half a dozen.
Has anyone got any possible way to still use PWM and arbitrary sample rate? Say up to 5 times faster or slower?
[code]
/* Arduino Audio Loopback Test
* Arduino Realtime Audio Processing
* 2 ADC 8-Bit Mode
* analog input 1 is used to sample the audio signal
* analog input 0 is used to control an audio effect
* PWM DAC with Timer2 as analog output
* KHM 2008 / Lab3/ Martin Nawrath nawrath@khm.de
* Kunsthochschule fuer Medien Koeln
* Academy of Media Arts Cologne
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
int ledPin = 13; // LED connected to digital pin 13
int testPin = 7;
boolean div32;
boolean div16;
// vars altered by interrupt
volatile boolean f_sample;
volatile byte badc0;
volatile byte badc1;
volatile byte ibb;
int ii;
byte dd[511]; // Audio Memory Array 8-Bit
pinMode(ledPin, OUTPUT); // sets the digital pin as output
pinMode(testPin, OUTPUT);
Serial.begin(57600); // connect to the serial port
Serial.println("Arduino Audio Loopback");
// set adc prescaler to 64 for 19kHz sampling frequency
cbi(ADCSRA, ADPS2);
sbi(ADCSRA, ADPS1);
sbi(ADCSRA, ADPS0);
sbi(ADMUX,ADLAR); // 8-Bit ADC in ADCH Register
sbi(ADMUX,REFS0); // VCC Reference
cbi(ADMUX,REFS1);
cbi(ADMUX,MUX0); // Set Input Multiplexer to Channel 0
cbi(ADMUX,MUX1);
cbi(ADMUX,MUX2);
cbi(ADMUX,MUX3);
// Timer2 PWM Mode set to fast PWM
cbi (TCCR2A, COM2A0);
sbi (TCCR2A, COM2A1);
sbi (TCCR2A, WGM20);
sbi (TCCR2A, WGM21);
cbi (TCCR2B, WGM22);
// Timer2 Clock Prescaler to : 1
sbi (TCCR2B, CS20);
cbi (TCCR2B, CS21);
cbi (TCCR2B, CS22);
// Timer2 PWM Port Enable
sbi(DDRB,3); // set digital pin 11 to output
//cli(); // disable interrupts to avoid distortion
cbi (TIMSK0,TOIE0); // disable Timer0 !!! delay is off now
sbi (TIMSK2,TOIE2); // enable Timer2 Interrupt
Serial.print("ADC offset="); // trim to 127
ii=badc1;
Serial.println(ii);
while (!f_sample) { // wait for Sample Value from ADC
} // Cycle 15625 KHz = 64uSec
PORTD = PORTD | 128; // Test Output on pin 7
f_sample=false;
OCR2A=badc1; // output audio to PWM port (pin 11)
// variable delay controlled by potentiometer
// when distortion then delay / processing time is too long
// for (cnta=0; cnta <= badc0; cnta++) {
// ibb = ibb * 5;
PORTD = PORTD ^ 128; // Test Output on pin 7
} // loop
// Timer2 Interrupt Service at 62.5 KHz
// here the audio and pot signal is sampled in a rate of: 16Mhz / 256 / 2 / 2 = 15625 Hz
// runtime : xxxx microseconds
ISR(TIMER2_OVF_vect) {
PORTB = PORTB | 1 ;
div32=!div32; // divide timer2 frequency / 2 to 31.25kHz
if (div32){
div16=!div16; //
if (div16) { // sample channel 0 and 1 alternately so each channel is sampled with 15.6kHz
badc0=ADCH; // get ADC channel 0
sbi(ADMUX,MUX0); // set multiplexer to channel 1
badc1=ADCH; // get ADC channel 1
cbi(ADMUX,MUX0); // set multiplexer to channel 0
f_sample=true;
ibb++; // short delay before start conversion
ibb--;
ibb++;
ibb--;
sbi(ADCSRA,ADSC); // start next conversion
[/code]
