Changing stepper motor move direction to opposite direction
Hello guys, I'm trying to use stepper motor 28BJY with ULN2003 motor driver. I want the stepper motor to turn 90 degrees to a direction, wait, then goes back to 0 degrees (but turning to opposite direction). I also used temperature sensor (TMP36) and photoresistor as an input for when the stepper motor will move.
The problem is that after turning the first time for 90 degrees. I can't seems to go back to 0 degrees (with opposite direction). If I use stepper.runToNewPosition(), it does go to 0 degrees, but in the same direction. I also tried moveTo() and move() but still doesn't work.
#include <AccelStepper.h>
#include <Chrono.h>
#define STEP_PER_REVOLUTION 2048
AccelStepper stepper(AccelStepper::FULL4WIRE, 6, 9, 10, 11);
LiquidCrystal_I2C lcd(0x27, 16, 2);
Chrono timer;
Chrono duration_timer;
const int photoresistor = A0;
const int tmp_sensor = A1;
const int red_led = 2;
const int green_led = 4;
const int buzzer = 3;
unsigned long duration = 5000;
int tmp = 0;
int light_val = 0;
int light_threshold = 200;
int target_revolution = 512;  // Turn the step motor 90 degree
bool start_water = false;
bool is_water_finished = false;
int state = 0;
  Serial.begin(19200);  // Open port communication between arduino and pc
  // Assign I/O pin for components
  pinMode(red_led, OUTPUT);
  pinMode(green_led, OUTPUT);
  pinMode(buzzer, OUTPUT);
  // Initizialize stepper motor
  stepper.setMaxSpeed(1000.0);
  stepper.setAcceleration(50.0);
  stepper.setSpeed(200);
  stepper.setCurrentPosition(0);
  stepper.moveTo(STEP_PER_REVOLUTION);
  stepper.enableOutputs();
  // Initizialize LCD I2C
  lcd.init();
  lcd.clear();
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Initializing...");
  delay(2000);
  lcd.clear();
  light_val = analogRead(photoresistor);
  tmp = analogRead(tmp_sensor);
  // Serial.print(light_val);
  // Serial.print("  ");
  // Serial.print(tmp);
  // Serial.println(state);
  // Serial.println(start_water);
  // Serial.println(is_water_finished);
  if (light_val < light_threshold)
    // If the value is below the threshold, start or reset the timer.
    if (!duration_timer.hasPassed(1000))
      duration_timer.restart();
      Serial.print(duration_timer.isRunning());
    // If the value is above the threshold, stop the timer.
    duration_timer.stop();
  if (duration_timer.hasPassed(duration) && !start_water) {
    // Set the flag to indicate that the check is completed.
    start_water = true;
  if(light_val < light_threshold && start_water && !is_water_finished)
    switch (state) {
      case 0: // Move to 90 degrees
        if (stepper.currentPosition() < STEP_PER_REVOLUTION / 4) {
          Serial.println("TURNING TURNING");
          stepper.runToNewPosition(STEP_PER_REVOLUTION / 4);
          Serial.println(stepper.currentPosition());
          state = 1; // Switch to the pause state
          Serial.println("DONE TURNING");
          timer.restart(); // Start the pause timer
      case 1: // Pause for 20 seconds
        if (timer.hasPassed(duration)) {
          state = 2; // Switch to the move back state
          Serial.println("WAITING WAITING WAITING");
      case 2: // Move back to 0 degrees
        stepper.runToNewPosition(0);  // I'm confused here
        is_water_finished = true;
        Serial.println("RETURNING RETURNING");
Try a move to -90 degrees.
Hello, thanks for the reply! I tried using stepper.moveTo(-512) after i stepper.setCurrentPosition(0). It does move but not in opposite direction.
       stepper.moveTo(-512);  // I'm confused here
       stepper.setSpeed(100);
       stepper.run();
       lcd.print(stepper.isRunning());
       // Serial.println(stepper.currentPosition());
       // Serial.println("RETURNING RETURNING");
@hii_kari_ri
Is you motor wired this way?
IN1 --> pin6
IN2 --> pin10
IN3 --> pin9
IN4 --> pin11
I find the MobaTools stepper library easier to use. That library has a function to turn the stepper to a specified angle (write()). Of course the steps per revolution must be accurately specified for it to work.
