I am writing a program to control the 7 servos in a Ohbot head using an ESP32 with a PCA9685 servo board. The base of the code was Adafruit's PCA9685 servo example. To use the modified code below you enter the element number, 0 to 6, and a - or + to move the servo, this is a test program. This works fine using the default address of 0x40. For this project I will have 5 of these Ohbots. So I changed the incidence for the boards address to 0x41, I also soldered the jumper on the board. I confirmed the address is right by running the I2C scanner example but this program now doesn't work. Do I have to modify something else to get it to work with the different address?
Here's my program:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// you can also call it with a different address and I2C interface
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40, Wire);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN 150 // This is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // This is the 'maximum' pulse length count (out of 4096)
#define USMIN 600 // This is the rounded 'minimum' microsecond length based on the minimum pulse of 150
#define USMAX 2400 // This is the rounded 'maximum' microsecond length based on the maximum pulse of 600
#define SERVO_FREQ 50 // Analog servos run at ~50 Hz updates
#define NUM_SERVOS 7
int currentServoNum = 0;
typedef struct {
int servoNum;
int minAng;
int maxAng;
int restAng;
int currentAng;
} ServoProps;
//properties for each servo
ServoProps servoProps[NUM_SERVOS] = {
{0, 0, 120, 55}, //head turn
{1, -15, 65, 35}, //head nod
{8, 20, 100, 55}, //eyes horizontal
{3, 55, 115, 85}, //eyes vertical
{4, 0, 40, 25}, //eyelids
{5, -20, 15, 15}, //top lip
{6, 20, 65, 65}, //bottom lip
Serial.println("8 channel Servo test!");
for (int i=0; i < NUM_SERVOS; i++) {
servoProps[i].currentAng = servoProps[i].restAng;
pwm.begin();
* In theory the internal oscillator (clock) is 25MHz but it really isn't
* that precise. You can 'calibrate' this by tweaking this number until
* you get the PWM update frequency you're expecting!
* The int.osc. for the PCA9685 chip is a range between about 23-27MHz and
* is used for calculating things like writeMicroseconds()
* Analog servos run at ~50 Hz updates, It is importaint to use an
* oscilloscope in setting the int.osc frequency for the I2C PCA9685 chip.
* 1) Attach the oscilloscope to one of the PWM signal pins and ground on
* the I2C PCA9685 chip you are setting the value for.
* 2) Adjust setOscillatorFrequency() until the PWM update frequency is the
* expected value (50Hz for most ESCs)
* Setting the value here is specific to each individual I2C PCA9685 chip and
* affects the calculations for the PWM update frequency.
* Failure to correctly set the int.osc value will cause unexpected PWM results
pwm.setOscillatorFrequency(27000000);
pwm.setPWMFreq(SERVO_FREQ); // Analog servos run at ~50 Hz updates
delay(10);
int extra = 0;
//pose the servos using the current angle settings for each channel
for (int j=0; j < NUM_SERVOS; j++) {
pwm.setPWM(servoProps[j].servoNum, 0, angleToPulse(servoProps[j].currentAng));
// check for serial input, values can be:
// 0 thru 7 to change servo channel
// + or - to change servo angle
// p to print out current pose values
if (Serial.available() > 0) {
char input = Serial.read();
if ((input == '=') || (input == '+')) {
servoProps[currentServoNum].currentAng += 5;
if (servoProps[currentServoNum].currentAng > servoProps[currentServoNum].maxAng) {
servoProps[currentServoNum].currentAng = servoProps[currentServoNum].maxAng;
} else if (input == '-') {
servoProps[currentServoNum].currentAng -= 5;
if (servoProps[currentServoNum].currentAng < servoProps[currentServoNum].minAng) {
servoProps[currentServoNum].currentAng = servoProps[currentServoNum].minAng;
} else if (input == 'p') {
Serial.println("nod, shake, eyes-hori, eyes-vert, eyelids, top-lip, bottom-lip");
Serial.print("{");
if (i > 0) {
Serial.print(", ");
Serial.print(servoProps[i].currentAng);
Serial.println("}");
currentServoNum = input - '0';
if (input != 'p') {
Serial.print(currentServoNum);
Serial.print(": ");
Serial.println(servoProps[currentServoNum].currentAng);
int angleToPulse(int ang){
int pulse = map(ang,0, 180, SERVOMIN,SERVOMAX);// map angle of 0 to 180 to Servo min and Servo max
// Serial.print("Angle: ");Serial.print(ang);
// Serial.print(" pulse: ");Serial.println(pulse);
return pulse;
Thanks for the help
John
