Changing the pin configuration of the SD Shield
I'm working on a project that has the Uno board and B.O.E shield with 4 servos connecting to pins 10, 11, 12, and 13, and now wanting to add an SD card shield to the mix but coming across that my servos are on the same pins as the SD shield pins.
Is there a way to change to code for the SD shield to work with my current project?
Or some other way to configure my servos to allow the SD shield to work as well?
Thanks for any help in advance. :)
No. The SPI interface is hardwired to those pins.
Ditch the shield. You don't need a shield to drive servos.
It doesn't look like the BOE shield uses SPI. Maybe you can modify the library to use other pins.
You can access the SD on other pins using software SPI.
The Adafruit version of SD.h has the option to use software SPI but it is slow https://github.com/adafruit/SD.
SdFat https://github.com/greiman/SdFat-beta also allows use of software SPI and is faster than the Adafruit software SPI but requires editing the SdFatconfig.h file to define the pins.
