Changing the time on a arduino clock
I have created a clock using a arduino and LCD display. The clock itself works just fine but i wanted to have a way to change the time without changing the numbers in the code itself. I ended up with this:
void change() {
 buttonh=digitalRead(A0, INPUT);
 if (buttonh=HIGH); {
   ++hour;
(I haven't created the minute yet because i wanted to troubleshot this first)
When i run it it just changes the hour at the same rate as the seconds, i tried putting the ++hour; into else aswell but i still dont get any response from the button.
I tested the cabling (or whatever you call it) with this code:
int buttonh;
 pinMode(A0, INPUT);
 pinMode(A1, OUTPUT);
 buttonh=digitalRead(A0);
 digitalWrite(A1, buttonh);
With this code a LED connected to A1 lights up whenever i press the button.
I would really appretiate any help as ive been trying to fix this by myself for a long time without any results.
Here is the entire code:
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int sec2 = 0;
int sec = 0;
int minute = 0;
int hour = 10;
int plush;
int plusm;
int buttonh;
int buttonm;
lcd.begin(16,2);
pinMode(A0, INPUT);
 change();
 lcd.clear();
 if (sec2 >5) {
   sec2 = 0;
 if (sec < 59) {
   ++sec;
 else  {
   sec = 0;
   ++minute;
 if (minute < 59) {
 else {
   minute = 0;
   ++hour;
 if (hour < 23) {
 else {
   hour = 0;
 lcd.setCursor(0,1);
 lcd.print(hour);
 lcd.setCursor(2,1);
 lcd.print(":");
 lcd.setCursor(3,1);
 lcd.print(minute);
 lcd.setCursor(5,1);
 lcd.print(":");
 lcd.setCursor(6,1);
 lcd.print(sec);
 change();
 if (hour >5)  {
   if (sec2 >2) {
     lcd.setCursor(0,0);
     lcd.print("Good morning!");
   else  {
     lcd.setCursor(0,0);
     lcd.print("Have a nice day!");
 if (hour <6)  {
   if (sec2 >2)  {
     lcd.setCursor(0,0);
     lcd.print("Go to sleep!");
   else {
     lcd.setCursor(0,0);
     lcd.print("I mean it!");
 if (hour >11) {
   if (sec2 > 2) {
     lcd.setCursor(0,0);
   else {
     lcd.setCursor(0,0);
 if (hour >13) {
   if (sec2 > 2) {
     lcd.setCursor(0,0);
     lcd.print("Good afternoon!");
   else  {
 if (hour >18) {
   if (sec2 > 2) {
     lcd.setCursor(0,0);
     lcd.print("Good evening!");
   else {
     lcd.setCursor(0,0);
     lcd.print("");
 if (hour >23) {
   if (sec2 >2) {
     lcd.setCursor(0,0);
     lcd.print("Good night!");
   else  {
     lcd.setCursor(0,0);
     lcd.print("");
 ++sec2;
 buttonh = 0;
void change() {
   ++hour
Please edit you post to have code-tags. See How to use the forum. This way it's just to damn hard to read it to spot the error.
The delays in your code prevent catching the button pushes, as they block the course of the program. You have to change the architecture of your code, by using the millis () instruction. There are several good tutorials on the forum about non blocking code.
Two distinctly different problems with this line, both of them fatal:
 if (buttonh=HIGH);
