Changing to Serial or Serial2.print depending on button state
Hi everyone, I'm struggling with the following situation. I would like to write a bit of code which changes from Serial to Serial2 depending on the the state of a button.
If Button = HIGH use Serial If Button = LOW use Serial2
i have quite a few strings to send but since they are the same for both the Serial and Serial2 connection i thought it would be quite nice to just change the Serial part of Serial.print instead of having two loops with the exact same messages but intended for different connections.
Here a bit of example code how i thought it could look like:
#define button 5
void setup(){
  Serial2.begin(9600);
  pinMode(button,INPUT);
  digitalRead(button);
  if(button == HIGH)
    //change Serial output to Serial.println
    Serialprint();
  else //button = LOW
    //change Serial output to Serial2.println
    Serialprint();
void Serialprint()
  Serial or Serial2.println("TEST"};  // dependend on if button high or low
Any ideas on this?
Thanks in Advance
Use a pointer or reference, then a simple assignment will direct output to the appropriate serial device.
Thanks for your response AWOL. Could you give me a short example how it would look like in my case?
typeof (Serial)& mySerial = Serial; // (global scope) A reference has to be initialised
if(button == HIGH)
    mySerial = Serial;
    mySerial = Serial2;
AWOL: if(button == HIGH)  {    mySerial = Serial;  }  else  {    //change Serial output to Serial2.println    mySerial = Serial2;  }
Very neat
...R
Of course, since you read a value from the pin and threw it away, and then compared the pin NUMBER to HIGH, none of that code will do what you want.
