Changing Uno I2C SCL clock frequency
Hellow,
can someone tell me why sometimes i see:
Wire.begin();
Wire.setClock(400000L);
and sometimes :
Wire.begin();
Wire.setClock(400000);
any difference ?
any difference ?
Yes, the first defines the literal explicitly as a long while the later does that implicitly. The result is the same as the compiler realizes without the hint that the number needs 32bit to be stored.
pylon:
When the results are the same, why are there two conventions of representation? There should be some merits/demerits like 'unsigned int' and 'uint16_t'.
You can code some stuff explicitly or implicitly, the result is the same.
uint16_t a = 39;
uint32_t b = a;
does the same as
uint16_t a = 39;
uint32_t b = (uint32_t)a;
but the second version does the cast explicitly.
If you have to specify a long literal explicitly you can use the 'L' postfix. Let's assume
class x {
  int foo(uint32_t value) { Serial.println("Long"); };
  int foo(uint16_t value) { Serial.println("Short"); };
  x test();
  test.foo(48);
  test.foo(48L);
void loop() {}
The first and the second call of the foo() method won't result in the same output.
