Hello. I'm new to Arduino and programming in general. I have been pulling my hair out for the last few days trying to figure out how to change a value over the serial monitor and would really appreciate some help. I am trying to change the number I have highlighted in the code below by typing the required value in to the serial monitor.
This demo and this one illustrate ways of reading data into an Arduino. Both demos work with the Serial Monitor although the second one is intended for use with a PC program.
The below code is for servos, but might be of value for your project. A numeric value is sent to the arduino via the serial monitor. The string of bytes sent is captured as readString. The captured readString is then converted into a number. Then the number is available for use.
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
myservo.write(n);
readString="";
reading = analogRead(sensorPin);
int celsius = reading/2;
if (celsius < n){
digitalWrite(relay,HIGH);
}else{
digitalWrite(relay,LOW);
Wright:
solved! thanks guys I finaly figured this one out with the code bellow. now off to write the python code! :~
you can certainly make your new code more compact....
String readString;
int sensorPin = A0;
int relay = 7;
pinMode(relay, OUTPUT);
int celsius = analogRead(sensorPin) / 2;
readString += c;
delay(2);
digitalWrite(relay, celsius < n ? HIGH : LOW);
readString = "" ;
and, what does the delay accomplish? you should control the frequency of updates on the other side... if they are less than a half second, your serial buffer will fill up and you will have a problem because it will combine the two transmissions.
anyways, you should maybe practice detecting delimiters so that you avoid that problem completely...
transmit your data like this:
#114
so that you can stop buffering when you get to that next '#' character
just a suggestion: add some error checking. if you are controlling an environment for a pet, for example. you don't want to accidentally fry your fish.
Similar code using a comma , as a data delimiter, so no delay needed.
//zoomkat 3-5-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
String readString;
#include <Servo.h>
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7); //the pin for the servo control
Serial.println("servo-delomit-test-22-dual-input"); // so I can keep track of what is loaded
//expect a string like 700, or 1500, or 2000,
//or like 30, or 90, or 180,
if (Serial.available()) {
if (c == ',') {
Serial.println(readString); //prints string to serial port out
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
//do stuff with the captured readString
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
