Changing variable via bluetooth during loop
G'Day Guys,
I'm very new to this so hope I'm putting this in the right section. I have a small project that is currently operating at its basic level. A "transmitter" and "receiver" Arduino Uno. A momentary button press on the transmitter starts the delay timer on the receiver; once the delay is complete, a relay fires. I have a number of receivers and a single transmitter.
So that setup is all working. But I would like to be able to do the following without having to restart the receivers or transmitter:
a) Use a smart phone to effectively turn a "receiver" on or off
b) Use a smart phone to control the delay individually in each receiver.
Ideally I'd like to use a bluetooth to turn each receiver on/off and change the delays. This isn't going to be a frequent process; maybe a few times on any given day. I suppose I could also use the "transmitter" code to control the delay and which receiver to send the signal to.
The problem is I am not familiar enough with the code to know how to implement this. I have tried a few methods of capturing serial monitor data, but it stops the loop that monitors the button state.
I can post my current code if that helps.
I don't believe it's a hard thing to do. I've spent hours trying to find out how to do it, reading and learning; but I just can't quite seem to get it.
Cheers,
Jase
It is essential that you post your current code.
If you've spent hours trying to do it, and failed, why have you concluded that it is easy?
