channel -1, channel 0, channel 13, channel 14 at WIFI
technical and legal.
sonnyyu I miss the question
Yun only supports Channel 1-12, missing -1,0,13,14.
Channel	Center Frequency	FCC Rules
-1	2.402 GHz		Part 97
0	2.407 GHz		Part 97
1	2.412 GHz		Part 97 & Part 15
2	2.417 GHz		Part 97 & Part 15
3	2.422 GHz		Part 97 & Part 15
4	2.427 GHz		Part 97 & Part 15
5	2.432 GHz		Part 97 & Part 15
6	2.437 GHz		Part 97 & Part 15
7	2.442 GHz		Part 97 & Part 15
8	2.447 GHz		Part 97 & Part 15
9	2.452 GHz		Part 97 & Part 15
10	2.457 GHz		Part 97 & Part 15
11	2.462 GHz		Part 97 & Part 15
12	2.467 GHz		Part 97 & Part 15
13	2.472 GHz		Part 97?
14	2.484 GHz		Part 97?
Yun only support Channel 1-12, missing -1,0,13,14.
Yes what is your question.
Technical, the channels are spaced closer together than the bandwidth needed for each channel, so they are not independent, in Wi-Fi there are only 3 totally separate channels.
Grumpy_Mike:
Which bandwidth 20Mhz or 40Mhz? Did you count big gap between channel 13 and channel 14 ( not spaced closer together like other) ?
Have a read of this
Grumpy_Mike:
Have a read of this
List of WLAN channels - Wikipedia
That one is missing FCC Rules and Channel -1 and Channel 0.
So what is stopping you using google to find one that has?
I can't tell for channels -1 and 0, but channel 13 is not available in north america List of WLAN channels - Wikipedia
Setting the "timezone" in the webpanel also sets the regulatory domain of wifi, making channel 13 available (if that country permits it)
