thanx tom for your reply
i have 4 relay its conected to pin 8,9,10,11 on uno board
and i use blotooth moudle and remotexy to control relay
i program put 2 switch on/off on remotexy code
in normaly as my case switsh 1 will control 1 relay when turn it and the number 2 switsh same things
now the other 2 relay i need to run it when the switsh 1 and 2 in off setuation
sorry for bad english
and this my code
-- New project --
This source code of graphical user interface
has been generated automatically by RemoteXY editor.
To compile this code using RemoteXY library 2.4.3 or later version
download by link http://remotexy.com/en/library/
To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
- for ANDROID 4.3.1 or later version;
- for iOS 1.3.5 or later version;
This source code is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
// RemoteXY include library //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__SOFTSERIAL
#include <SoftwareSerial.h>
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL_RX 2
#define REMOTEXY_SERIAL_TX 3
#define REMOTEXY_SERIAL_SPEED 9600
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,2,0,0,0,37,0,8,13,0,
2,0,55,21,22,11,16,28,134,36,
79,78,0,79,70,70,0,2,0,25,
21,22,11,16,27,134,36,79,78,0,
79,70,70,0 };
// this structure defines all the variables of your control interface
struct {
// input variable
uint8_t switch_1; // =1 if switch ON and =0 if OFF
uint8_t switch_2; // =1 if switch ON and =0 if OFF
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
#define PIN_SWITCH_1 8
#define PIN_SWITCH_2 10
RemoteXY_Init ();
pinMode (PIN_SWITCH_1, OUTPUT);
pinMode (PIN_SWITCH_2, OUTPUT);
// TODO you setup code
RemoteXY_Handler ();
digitalWrite(PIN_SWITCH_1, (RemoteXY.switch_1==0)?LOW:HIGH);
digitalWrite(PIN_SWITCH_2, (RemoteXY.switch_2==0)?LOW:HIGH);
// TODO you loop code
// use the RemoteXY structure for data transfer
